Q about current article: On-demand Hydrogen Generation : ACS Nano Letters
The discussion centers around a research abstract that mentions a process for splitting water molecules without the use of light, heat, or electricity. A key question raised is the source of energy for this reaction. It is clarified that the reaction involving silicon (Si) and water (H2O) is exothermic, producing silicon dioxide (SiO2) and hydrogen gas (H2). This exothermic nature indicates that the reaction releases energy, which is sufficient for the water splitting process. The conversation also touches on the similarity of this method to using an aluminum/gallium alloy for water splitting, emphasizing that the initial assumption of a catalytic process was incorrect.
pdxjjb
Here is the abstract: http://pubs.acs.org/doi/abs/10.1021/nl304680w
I would need to pay the $35 so I have not read the full text.
Question: it says "...without Light, Heat, or Electricity." Where is the energy required to split the water molecules coming from?
Jeff
Chemistry news on Phys.org
2H2O +Si -> SiO2 +2H2
This reaction is very exothermic due to the high energy of formation of SiO2.
In a way it is not much different from using Al/Ga alloy for the same purpose.
Thank you both. I foolishly thought they might be claiming some kind of catalysis. I saw the error of my ways soon after posting.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
