QM - Eigenfunction / Eigenvalue Problem
danny271828
Find the eigenfunctions and eigenvalues for the operator:
a = x + \frac{d}{dx}
2. The attempt at a solution
a\Psi = \lambda\Psi
x\Psi + \frac{d\Psi}{dx} = \lambda\Psi
x + \frac{1}{\Psi}\frac{d\Psi}{dx} = \lambda
x + \frac{d}{dx} ln(\Psi)= \lambda
\frac{1}{2}x^{2} + ln(\Psi) = \lambdax +c
\Psi = e^(-\frac{1}{2}x^{2}+\lambdax+c)
\Psi = e^(-\frac{1}{2}x^{2}+\lambda)\Psi(0)
Not sure from here... I think I plug into initial equation?
a\Psi = \lambda\Psi
substituting and using chain rule I obtain...
x\Psi + (\lambda-x)\Psi = \lambda\Psi
so x + (\lambda - x) = \lambda
so \lambda = \lambda nope I guess I don't do that... good check though, so I guess this is the correct way to solve for eigenfunction... Can someone help me with finding \lambda?
Normally, the spectrum of allowed eigenvalues \lambda is obtained from the normalization condition. I.e., there should be a non-zero normalization constant (which you denoted by \Psi(0)) such that the integral of the square of the modulus of the wavefunction over entire space (the total probability of finding the particle) is equal to 1. In your case, this doesn't matter, because the wavefunction is normalizable for all real \lambda. So, all values of \lambda are allowed. However, in more complex cases such as a particle in a potential well - the normalization condition would allow you to find the discrete spectrum of energy eigenvalues.
Eugene.
P.S. Perhaps, it is not a good idea to ask the same question in three different threads.
https://www.physicsforums.com/showthread.php?t=182374
https://www.physicsforums.com/showthread.php?t=182369
Thanks Eugene...
Sorry about that... Kind of new to this... I havn't seen a way to delete your own posts... but there probably is one...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
