Quadratic Has A Maximum Value Or A Minimum Value
The discussion focuses on determining whether the quadratic function F(x) = -x² - 6x - 7 has a maximum or minimum value, with the consensus that it opens downward, indicating a maximum. To find this maximum, participants suggest using either calculus or completing the square. There is also a request for help with a system of equations, where participants provide guidance on rearranging and substituting to solve for the variables. Overall, the thread emphasizes the importance of showing work to identify errors in calculations.
Chikawakajones
Due Tomorrow Please Help Now!
#2 Tell Whether The Quadratic Has A Maximum Value Or A Minimum Value. The Find The Value. Round To The Nearest Tenth. :confused:
F(x)= -x² -6x - 7
#3 Let y = | x+a | +b, Where a ‡ 0 and b ‡ 0 . Explain how the values of a and b affect the graph of the functions as compared to the graph of y= |x|.
I NEED HELP FAST HURRY! :cry: THANK YOU!
Hints:
#1 Solve. Round Decimal Answer To The Nearest Tenth.
x + y = 6 -(1)
y + z = 4 -(2)
x + z = 2 -(3)
Take equation (1). Rearrage to get y in terms of x.
Substitute that into equation (2) to get a new equation for x and z - equation (2b)
Eliminate either x or z from equations (2b) and (3), solving simultaneously.
Back-substitute to get the other two solutions.
F(x)= -x² -6x - 7
This is a parabola. Which way round does it go? Peak at the top, or the bottom? How can you tell?
To find the maximum or minimum, you can either differentiate (if you know calculus), or complete the square (if you don't).
How do the following graphs differ:
y = sin x
y = sin x + 6
How about these ones:
y = sin x
y = sin(x+6)
Apply that to your problem.
If you need more help, let us know.
I Need More Help. I DONT GET IT.
Well, let's start with the first one:
x + y = 6
y + z = 4
x + z = 2
You have three equations and three unknowns. Pretty simple here.
Lets write the first equation in terms of y.
y = 6 - x
(*Remember when you move a term to the other side of the equals sign, its sign changes*)
Now, we know what y is. So we can take that and substitude (6-x) wherever there is 'y' term.
Take a look at the second equation:
y + z = 4
We now know what y is, so we can turn this into a new equation.
(6 - x) + z = 4
6 - x + z = 4
z - x = -2
Now let's take a look at the third equation
x + z = 2
Lets rearrange this bad-boy in terms of z
z = 2 - x
(*Isn't this fun?*)
Knowing that
z - x = -2
We can now write
2 - x - x = -2
-2x = -4
I hope you can take it from there.
thank you, how about the 2nd and the 3rd ones?
need answers
Well, for the second question let's look at your equation.
F(x)= -x² -6x - 7
Its in the form ax^2+bx+c which means that you are given a parabola
This is what a f(x) = x^2 looks like
Now what we have here is a little different. Our parabola has a negative sign infront of it. This means that it will be upside down, or opening downwards.
From that you should be able to figure out if it will have a MAX or a MIN.
To find the MAX/MIN value just set dy/dx(f(x)) = 0
Solve for x, plug into f(x) and you'll get your y value.
I'll put in just as much effort as you do, chikawakajones.
#2: We hav
That's about it.
--J
how do u solve for x?
Chikawakajones said:
need answers
#2: We hav
That's about it.
--J
haha :smile:
just help me...
Well, you have two options. If you know calculus you can take the derivative of f(x), or you can complete the square.
Either way is really easy. And you'll get the same value for x.
I'm going to assume right off the bat that you don't know calculus. So, I'll explain how to complete the square
f(x) = -x^2-6x-7
For the general equation:
x^2 + bx + c
Take half of the middle term (b) and add its square to the last term (c).
(x-b/2)^2 + c + b^2
set
x-b/2 = 0
solve for x
plug x into F(x)
(x, F(x) ) are your points
im doing other problems right now...that is why i need as much help i could get
for the x value, i got -22. is this right?
Err--no. Not quite sure how you got that.
Lets look at this again, and break it down.
We have
f(x)= -(x^2) -6x -7
Lets break this bad boy down.
Term A is going to be -(x^2)
Term B is going to be -6x
Term C is going to be -7
Lets take out the x's
b = 6
c = -7
Now the general formula is
(x-\frac{b}{2})^2 + (\frac{b}{2})^2 + c
Now take your (x-\frac{b}{2})^2 part
and set x-\frac{b}{2} = 0
solve for x
plug into your oringal function to get y
Or you know what in this case just take b (READ: 6) divide it by two (READ: 6/2) and then set x - b (READ: -x - 6/2) to 0 (READ: x + 6/2 = 0)
Then plug that value (READ: -6/2) into f(x) to get your Y value.
If x=-22 is supposed to be the x value of the maximum point, the answer is "no - that's not right."
Please post your working so we can tell you where you went wrong.
