Qualitative advice on two phase flow problem.
The discussion revolves around a two-phase flow scenario in a tank with nitrogen gas and liquid hydrogen peroxide. When a valve at opening A is closed, the pressure is expected to drop from 33 bar to atmospheric pressure at opening B. The user seeks qualitative insights on the speed of this pressure drop, questioning whether it would be rapid (under 5 seconds) or slow (over 10 seconds). There is an implication that the flow might reach sonic velocity, indicating choked flow conditions. The conversation highlights the challenges of simulating two-phase flow in software like SolidWorks and the need for further exploration in COMSOL.
SteveNgabo
Hi guys I have a rather qualitative question. let's imagine a tank with two openings. pressure is measured at one opening (A) to be at a constant 33 bar at time t=0s. the other opening(B) is at atmospheric pressure.
Inside the tank we have a two phase flow half is N2 gas and the other half is H2O2(hydrogen peroxide in liquid form) the tank itself is made out of aluminium for weight saving purposes and it's not very big about the size of a paintball tank.
The question here is if we closed opening A with a valve (solenoid) so that pressure at A becomes 0, how fast would the pressure decrease. I know this is not an easy question because it is time dependent. I had to try and simulate this on solidworks but two-phase flow is not available. So before trying it with Comsol I would like to know maybe from someone's experience if it will be fast pressure drop(<5sec) or a slow one(>10sec)
Fast I think.
With a pressure drop as big as that, the flow velocity would be sonic (i.e. choked flow) I assume?
Your description sounds less tank and more a nozzle or a pipe.
the B opening leads to a nozzle indeed. Thanks for your insight
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
