Quantum numbers of N/Deltas resonances
headbomb
I've been working on something and I seem to have hit a noose.
The PDG lists many N/Delta resonances, but let's focus on four of them, each with JP=3/2+:
*N(1720), P13, http://pdg.lbl.gov/2009/listings/rpp2009-list-N-1720-P13.pdf
*Delta(1232), P33, http://pdg.lbl.gov/2009/listings/rpp2009-list-Delta-1232.pdf
*Delta(1600), P33, http://pdg.lbl.gov/2009/listings/rpp2009-list-Delta-1600.pdf
*Delta(1920), P33, http://pdg.lbl.gov/2009/listings/rpp2009-list-Delta-1920.pdf
where spectroscopic state is noted L2I 2J.
Now, if I want to identify the quantum numbers of these particles, J is given as 3/2, from P we know that L is 1, and thus S needs to be 1/2 (|J|=|L+S|, ..., |L-S| in integer steps). And now I'm left with only n to distinguish between a N and a Delta, which makes no sense. What am I doing wrong?
This spins of the N and the Delta are intrinsic spins. There is no L or S.
The parity refers to how they behave in decay to a pi N state.
Then the Delta(3/2) or the N(3/2) each decay to L_pi=1 and s_N=1/2.
They are distinguished by their Ispin.
N's have isospin 1/2. Deltas have isospin 3/2. That's the definition of the difference.
If there is no L, then why is L given (the P in P13/P33, see http://pdg.lbl.gov/2009/reviews/rpp2009-rev-n-delta-resonances.pdf). If there is no S, then why is J not equal to L?
Isospin is not fundamental. I want the fundamental difference between the N(1720) and the Delta(1920)/Delta(1600) in terms of fundamental quantum numbers.
What do you mean it's not fundamental? Why then are the Lambda and Neutral Sigma different particles?
Different internal symmetries (different wavefunctions).
I just might have answered my own question.
As I said in my post, the L and S refer to the decay channel -->pi + N, or to the resonance channel in pi-N scattering.
Ispin is needed if quarks are not used. In the quark model, Ispin can be dispensed with,and the N and Delta difference is in their quark spin states. The same is true for the Lambda and Sigma.
Any book or online refs I can check on that topic?
Yes, which then leads to the question, how would one write the analogous states for the equivalent \Sigma^- (dds) states? These would all be P33 states [edit:I meant P23, my bad]. Would mass be the only distinguisher?
Most older books on particle physics would discuss pi-N scattering.
There is a spin 1/2 Sigma-(dds) with the three quark spins adding up to 1/2.
The spin 3/2 dds state is now called the Y*. Its three quark spins add up to 3/2.
The Y* is not a P_33 state because its isospin is 1.
Yes, but do you know of a book that specifically discuss these assignments of L with particular channels (instead of being a quantum number). Also, I've spoken with my teacher about this and he says that his impression is that L indeed is a quantum number. We are both quite puzzled by this.
That doesn't make any sense. Spin three dds states are called \Sigma, just like the spin 1/2 dds states are called \Sigma. The only variation out there is to place a star in the decuplet Sigmas (\Sigma^*). If there's something called the Y* with the dds assignment, then it must've been a placeholder name for a resonance that will be changed into a \Sigma^ or \Sigma^* as soon as the dds assignment is confirmed.
And I meant P23, my bad.
I'm sorry, Ihad the notation backwards. It was called the Y* years ago, but now is just listed in the pdg as Sigma, not even having the star for 3/2. Sigma- now refers to any quark model state dds of any J.
If you look at the summar tables for Sigmas, there are some with L>1 and J>3/2.
For instance, §(1775) D_15 is observed as a bump in pi-Sigma final states with angular distribution corresponding to L=2 and J=5/2.
