Question about invertible matrix
  • Thread starter Thread starter tysonk
    Matrix
The discussion revolves around the properties of invertible matrices, specifically addressing whether the sum of an invertible matrix and the identity matrix remains invertible. Participants also explore a related problem involving the inversion of a matrix equation.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants question the invertibility of the matrix resulting from the addition of an identity matrix to an invertible matrix. There are attempts to clarify the reasoning behind the invertibility of a derived expression involving multiple matrices.
The discussion includes various perspectives on the properties of invertible matrices, with some participants providing insights into the conditions under which certain matrices remain invertible. There is an ongoing exploration of the relationships between the matrices involved, but no consensus has been reached.
Participants are working under the constraints of a homework problem, which requires them to justify the invertibility of specific matrices without providing complete solutions. The original equations and assumptions are central to the discussion.
tysonk
Hi, I have a question about invertible matrix. If A is invertible does adding the identity matrix to it still make it invertible.
In other words, A +I = B , it B still invertible? Why?
Thanks.
-I is invertible. Adding I to it gives you something pretty noninvertible.
What about
The question actually is:
Solve for X. If you need to invert a matrix explain why that matrix is invertible.
A,B,X, are nbyn matrices. A,X, A-AX are invertible.
(A-AX)^-1 = X^-1 B
So I got X = BA(I + BA) ^-1
I'm just not sure why (I + BA) is invertible.
Thanks for the help
(A-AX)^-1 = X^-1 B
Thanks for the help
You got there by showing BA=(1+BA)X, right? If X-AX is invertible and X is invertible then B is invertible from your original equation, yes? Now if B is invertible, A is invertible and X is invertible, then (1+BA) is invertible. If you have an equation like J*K=L and two of the three matrices are invertible, then the third is invertible. And haven't you got the BA and (1+BA)^(-1) factors in reverse order?
Makes sense, Thanks!
Edit: yes, the ordering should be the other way.
Hi, is there anyway you could go over how you got to the form X= BA(I+BA)^-1 from the original equation?
Starting from (A-AX)^(-1)=X^(-1)B, begin by inverting both sides. Then expand and try to get all the X's on one side.
  • · Replies 40 ·
  • · Replies 20 ·
