Question for my Physics Project.
  • Thread starter Thread starter Kuzey Cem
    Physics Project
Bacteria carried by air do not fall to the ground like other objects due to air resistance, which opposes their motion and is influenced by their velocity. The drag force acting on these tiny organisms is significant because their small size means they experience a relatively low velocity in comparison to the air. Additionally, the discussion touches on the mechanics of a water pump piston, highlighting that pulling and pushing the piston involves pressure and force, which are fundamental concepts in physics. Understanding these principles is essential for grasping how various forces, including static electricity and buoyancy, interact in different scenarios. The conversation emphasizes the importance of recognizing the role of air resistance in both biological and mechanical contexts.
Kuzey Cem
Some disease-causing bacteria are carried by the air. Why don't these organisms fall to the ground as other objects?
Drag equation might be useful here (I think)
I think it is because of air resistance. It is the force that are in opposition to the relative motion of an object moving through the air. It depends on velocity. It is calculated by using the drag equation.
However, I couldn't really figure out the connection between these.
Hi I am Kuzey Cem and I am a 12 year old student in Turkey. I am interested in any science, especially Physics and Biology.
Which normally requires more work: pulling the piston of a water pump out of the cylinder or pushing it back in?
I think it is related to pressure, and also force. But I don't know how pistons really work.
When you wipe your feet to the carpet, how do your voltage and that of the carpet change?
I found out that this is about static electricity and charges.
Welcome to PF;
i.e. what makes things float?
Some other force opposing gravity is a good start, and drag is one of them.
You correctly observe that drag is proportional and opposite the velocity.
Consider though, if something is floating, as opposed to falling, then what is it's velocity like?
Therefore, how much drag force is acting?
Are there other things that can make something float?
Which normally requires more work: pulling the piston of a water pump out of the cylinder or pushing it back in? ... I think it is related to pressure, and also force. But I don't know how pistons really work.
... Then I suggest you go find some pictures of pistons in operation.
Seriously - this is a basic concept that will be used over and over again so you need to get a feel for it.
The pump is a hollow cylinder with a hole in the bottom, with a valve so water can only flow inwards.
The piston part is a solid cylinder that fills the inside - but can slide up and down.
You pull up on the piston, the piston pulls water into the chamber. When it is all the way up, you push down on the piston, and water flows out another hole, through another valve - which allows water to only flow out.
What determines the work done during each part of the cycle?
They are not floating in the same way hot-air balloons do. They are just tiny, so air resistance is extremely relevant, and the air in our environment is always in motion.
Correct.
Yes - there are forces at work besides buoyancy ...
So if the bacteria is flowing, it has a low velocity? Is that correct?
A low velocity relative to the air, yes.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
