Question regarding optics(prism)
  • Thread starter Thread starter shakeysg
The discussion centers on determining the index of refraction, n, for a 90-degree triangular prism using Snell's law. The user initially struggles to relate the angles of incidence and refraction, particularly θ1 and θ4, while trying to eliminate variables. After some back-and-forth, they realize that using the relationship between cosine and sine can help simplify the problem. Ultimately, they successfully express n in terms of θ, indicating that the solution is achievable with the right approach. The conversation highlights the importance of revisiting fundamental relationships in optics to solve complex problems.
shakeysg
figure shows a 90 degrees triangular prism of refractive index n whereby light enters at point A with an incident angle of θ. The light then refracts at point B with an angle of refraction of 90 degrees.
determine index of refraction, n in terms of θ. refer to figure attached.
using snell's law of refraction,
n.sinθ=n1.sinθ1
first I used an snell's law to get an eqn
1.sinθ=n.sinθ1----------------------(1)
using properties of angles and triangles I got
θ2, θ3 and θ4.
θ1=θ3, θ2=θ4.
using snell's law again I got
n.sinθ4=1.sin 90 degrees
n.sinθ4=1
I tried using trigonometry to compute the thetas together and eventually eliminate θ1. But I was not able to do so. Am I missing something?
Since I got stuck, I thought if θ1=45 degrees, getting n in terms of θ is not a problem. But I reasoned to myself that it cannot be possible as I do not know θ4 and n. So making an assumption is not right. I think? I could be wrong though.. hmm..
help would be greatly appreciated and I am sorry if posted anything wrongly such as the format or thought process since this is the first time I am posting.
Thanks!
Syeh
You have two equations
sinθ = n sinθ1
n sinθ4 = 1
Can you find a relation between θ1 and θ4?
hmm.. thanks for replying.. I went through that before.. basically 1=ncosθ1 since 90 degrees-θ4=θ1=θ3. and if i were to combine both eqns together, it will result in
sinθ=tanθ1.
the thing is I couldn't eliminate θ1 but I eliminated n instead. I even tried substituting other values of relevant θ into the equation and it got me more irritated. It feels like I am missing something right before my eyes and I cannot comprehend what is it that I missed. oh man. Anyway, this qns is the first part of a 4 parts 12 marks qns. So the solution shouldn't be too complicated. Thanks for replying again.
shakeysg said:
basically 1=ncosθ1
So cosθ1=1/n. What is sinθ1 in terms of n?
ehild
oh my. hahaa. thanks for making me rethink the qns. i managed to n in terms of theta. thanks again! : D
