What Speed is Required for a Half-Court Jump Shot in Basketball?
  • Thread starter Thread starter bam3211
    Unknowns
To determine the speed required for a half-court jump shot in basketball, the player must release the ball at a height equal to the basket while launching it at a 54.0° angle from a distance of 14.0 meters. The problem involves calculating the initial velocity needed for the ball to return to its original height after traveling horizontally. By breaking down the motion into vertical and horizontal components, one can establish equations based on the known vertical distance, horizontal distance, and gravitational acceleration. This approach allows for solving the equations to find the initial velocity, reducing the complexity of multiple unknowns. Understanding these principles is essential for calculating the required speed effectively.
bam3211
A basketball player tries to make a half-court jump shot, releasing the ball at the height of the basket. Assuming that the ball is launched at 54.0°, 14.0 m from the basket, what speed must the player give the ball?
There are a lot of unknowns and i don't know where to start
any help?
Well, if the ball is released at the height of the basket it means that you have to find the initial velocity that will result in the ball returning to its original y position over a horizontal distance of 14 metres.
There is only one unknown: the speed of the ball.
Note that the ball is released at the height of the basket...
any help?
Don't be intimidated by multiple unknowns - all it means is a few more steps.
Start by determining what you know. Don't worry if you have to define one thing (such as velocity) in terms of another unknown (such as time).
In this case you are looking for velocity. Since you have an angle, you can define it by its vertical and horizontal components. You know the total distance it is traveling vertically (it starts and ends at the same height) and you know the horizontal distance it travels (given as 14.0 m). You also know the acceleration in each direction (a = g vertically, a = 0 horizontally). From this, you should be able to develop two equations with two unknowns in each (make sure they are the same unknowns). Solve one equation for one unknown in terms of the other, then substitute that into the other equation. You now have only one unknown and can solve for that.
Hope this helps get you started.
