Quick Divergence Theorem question
The discussion revolves around applying the divergence theorem to evaluate the flux of the vector field V through a hemisphere. The divergence of V is calculated as 1, leading to a volume integral over the hemisphere that results in 2πa³/3. Participants express confusion about the distinction between flux and flux density, with some clarifying that the divergence represents flux density. The hint suggests that a direct evaluation of the flux may not be the easiest approach, prompting a discussion on the correct interpretation of the problem. Overall, the thread highlights common misunderstandings in vector calculus, particularly regarding the divergence theorem.
Stef42
Use the divergence theorem in three dimensions
\int\int\int\nabla\bullet V d\tau= \int \int V \bullet n d \sigma
V= (3x-2y)i + x4zj + (1-2z)k
through the hemisphere bounded by the spherical surface x2+y2+z2=a2 (for z>0) and the x-y plane
Hint: The direct evauation of the flux may not be the easiest way to proceed
I found it pretty simple which means I probably messed up (and I'm not sure what the hint is talking about
ok so the divergence is
\nabla \bullet V = 3-2=1
and the integral over the volume of the hemisphere (using spherical polar coordinates) is
\int_{0}^a r^2 d \tau \int_{0}^{2\pi} d\phi \int_{0}^{\pi/2} sin\theta d\theta = \frac{2\pi a^3}{3}
So am I doing it completely wrong? I don't know the answer but if anyone could look through it and spot anything I would really appreciate it
Hi Stef42! :smile:
(have a del: ∇ and a theta: θ and a phi: φ and a sigma: σ and use \cdot instead of \bullet :wink:)
Looks fine to me …
I think the hint just means don't use V.n, which is the flux, use ∇.V … though that's a bit unnecessary since they've already told you to :rolleyes:
thanks for the speedy response tiny-tim :-)
Ok so just to clear up:
∇.V= divergence of vector field V
V.n= flux
So then the sigma integral is flux density ?
So what did I calculate? flux density aswell? wasn't I supposed to find the flux? :confused:
oooh, I get confused between flux and flux density …
anyway, V.n is definitely fluxy, and ∇.V definitely isn't :wink:
well, at least I'm not the only one who gets confused, damn vector calculus :frown:
well from my lectures notes:
"The divergence represents the flux density of the vector field and, because of the derivative operation, has an associated Fundamental Theorem of Calculus called the divergence theorem : (quotes equation)"
hmm think I'll go talk to him tomorrow :)
