Quick question about uncertainty calculation
To calculate the uncertainty of the product of two values, A and B, the discussion highlights two main methods: using partial derivatives and applying the square root of the sum of the squares of the uncertainties. The formula for relative uncertainty is given as δC/C = δA/A + δB/B, derived from differential calculus. It is noted that if the uncertainties are independent, the square root method can be used, which provides probable error rather than maximum error. The thread emphasizes the importance of understanding these methods to accurately calculate uncertainty in experiments.
mjolnir80
lets say we have A * B
A=12.8 + 0.2
B=3.75 + 0.08
how would we calculate the new uncertainty value
ive seen soo many ways of doing this I am a bit confused
thanks in advance
any equation used to calculate uncertainty
the 2 main ways I've seen is one involving partial dervatives and the other is taking the square root of the answer times the (uncertainties/value)2
im a little confused about which one to use
If C=AB, then
\frac{\delta C}{C}=\frac{\delta A}{A}+ \frac{\delta B}{B}
this is obtained using differential calculus.
(A+ε1)*(B+ε2)
AB+Aε2+Bε11ε2
so if we disregard the final term the incertainty would be Aε2+Bε1
partial derivative of AB with respect to A is B
partial derivative of AB with respect to B is A
does that help?
rock.freak667 said:
If C=AB, then
whats that called? I want to look that up. it looks interesting.
