How Many Potassium Ions Pass Through a 0.30-nm Channel in 1.0 ms?
  • Thread starter Thread starter kyang002
    Electricity Flow
A 0.30-nm potassium ion channel carries a current of 1.8 pA, and calculations show that approximately 3.0 x 10^5 potassium ions pass through the channel in 1.0 ms. The current density in the channel is calculated to be 1.2 x 10^-6 A/m^2. The discussion highlights the use of equations related to charge flow, area, and ion characteristics to derive these values. Participants emphasize the importance of understanding the relationship between current, charge, and time in solving the problem. The calculations provide a clear method for determining both the number of ions and current density.
kyang002
Measurements with microelectrodes have shown that a 0.30-nm-diameter potassium ion (K+) channel carries a current of 1.8 pA.
How many potassium ions pass through if the ion channel opens for 1.0 ms?
What is the current density in the ion channel?
I am completely lost for this one. Anyone know of any equations that I can use?
Current is, its I = dQ/dt, the flow of charge through a point, through time. Like measuring the flow of water through a pipe.
The area the flow is going through (the inner area of the "pipe") because they give you the diameter. area = pi*r^2, 2*r = diameter.
I = dQ/dt = n*A*q*dx/dt = n*A*q*Velocity
so first solve I = n*A*q*Velocity
then use that with velocity = dx/dt to get dx.
Then use dQ = (n*A*dx)*q
to get dQ.
But I am stuck on how to solve for the variables and how to complete the problem. Can anyone help me out with the answer?
Needless to say, you're making this more difficult than you need to. What's the definition of an ampere? One ampere is one coulomb of charge moving past a fixed point each second. Each potassium ion has a fixed charge, +e. One coloumb of charge contains 6.25 * 10^18 such ions.
1.8 pA = \frac{1.8 \cdot 10^{-12} C}{s} \cdot \frac{6.25 \cdot 10^{18} \textrm{ ions}}{C} \cdot 1 \cdot 10^{-3} s
Perform the multiplication and get your answer in number of ions.
- Warren
To solve for the number of potassium ions passing through in 1.0 ms, we can use the equation dQ = n*A*q*dx, where dQ is the charge passing through, n is the number of ions, A is the area of the ion channel, q is the charge of each ion, and dx is the distance the ions travel in 1.0 ms. We can rearrange this equation to solve for n: n = dQ/(A*q*dx).
Plugging in the given values, we get n = (1.8 pC)/(π*(0.30/2)^2*1.6*10^-19 C*0.30 nm*10^-9 m/nm) = 3.0*10^5 ions.
To calculate the current density in the ion channel, we can use the formula J = I/A, where J is the current density, I is the current, and A is the cross-sectional area of the channel. Plugging in the given values, we get J = (1.8 pA)/(π*(0.30/2)^2) = 1.2*10^-6 A/m^2.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
