Race car suspension Class
1,808 replies · 938K views · last reply
My question was in reference to the rear suspension, not front. I have roll center software that does rear suspension, but it will only work for a symmetrical triangulated four link. I can do it manually with a CAD program but I’m not exactly sure how because the instant centers for the upper and lower trailing arms never intersect. The article I linked has a diagram of the GM metric triangulated four link rear suspension in case you aren’t familiar with it.
Dontl
the artice lyou attached tells you how to calculate rear RC. Even though the 4 links do not meet in anyone plane, the RC height is easy to calulate. The RC location to vehile centerline is a midpoint between link mount points on top of rear axle.
My Circle Track Analyzer has a simplified 4 link rear suspension recommended for 4 link Chevelle.
You are pretty limited on adjustments with metric 4 link.
It is what it is and since you can not adjust it up or down, I would concentrate on adding as much rear roll steer as you can get to it. Hope this helps.
Jtcox3000 said:
Ranger Mike, I’m at a loss on how to get the left front down. This is a new car, moved roll center left, raised motor up 1/2” and to the left 1”.
Man what a difference a year makes! Hey Guys, just wanted to thank you for the input you gave me on our dirt mod that was lifting the left front Really bad! We went from a mid pack race car to now winning our 7th race of the year. We won 2 track championships and a Sunoco summer series event this year alone. Couldn’t have done it without you guys and this awesome forum! And yes this is the same car!
Ranger Mike, logicindustries you guys are the best! Couldn’t have done it without you both. So thankful for this forum, the information is here! just got to read it, understand it and apply it! Felt like a real dummy asking for help but now I’m so glad I did!
Congrats.
Can you share with us what all changes you made from the recommendations, and what you think worked and what didn't work?
Hey RM,
Every time I have a question I always revisit this forum (have intermittently frequented since 2014). I know you are a big proponent for the performance trends software and that is my next investment. While I'm budgeting the cash for this I do have a question.
While I was mapping out the rear suspension of my dirt late model I was thinking about instant centers. On the dirt cars we do have birdcages on both sides of the rear axle which is where my question lies. In order to calculate the instant centers of the rear end you have to use the lower bars for sure. Although, I'm not sure if you would use any other links to capture the instant centers. Both sides upper bars are angled in the positive direction so you would get no convergence other than aft axle. The lift arm is level at static so that wouldn't be the correct option either. The one given i have is that obviously we do have a positive anti-squat value on the left rear given that it hikes as soon as throttle is applied. Would you suggest just using the just lower bar to map out instant center? I've consulted all of the textbooks I have and have not found much in the way of instant center calculation for this scenario. I'm interested in the theory as it seems to help me conceptualize my direction, execution and optimization.
Also, do you have any reference that would help me understand the math of the instant center? I see a lot of articles referencing 100% but I'm not understanding what the base value and calculated value is that would yield your specific percentage.
I've done a ton of work mapping and optimizing lift bar (torque arm) application and optimization. This is the next piece to the puzzle.
Wylde said:
Hey RM,
Keep in mind that on a dirt late model you have a live axle decoupled suspension, so the typical anti-squat calculations you would normally find in textbooks for 3-link suspensions etc. do not apply. You basically have four sources of anti-squat in a typical dirt late model utilizing a 4-link rear suspension.
The forces generated by the 5th arm lift bar, the forces generated by the left set of four bar links, the forces generated by the right set of four bar links, and the forces generated by the j-bar. The 5th arm forces are a direct response from axle wrap, so that reaction force is pretty straight forward. You then have to determine the instant centers for both the j-bar system of links and the left and right four bar systems of links.
The anti-squat from the j-bar system is generated by taking a moment about that systems IC from the lateral forces at each of the rear tires. The left and right four bar links are determined by taking a moment about their ICs as well. The force you use is the force that is generated at the axle tube by the rotating tire. This approach is only valid because the 4-bar links systems (via the rotating birdcages) are decoupled from the axle tube.
Keep in mind that these calculations on their own are pretty useless other than for conceptual purposes. They should be used in a large set of equations that define the vehicle as a whole, where the anti-squat forces are but a small part of the overall picture. As for your question about how to determine the 4-bar link instant centers. You would have to project the links onto a two dimensional plane (i.e. a sideview) and find the intersection of the projected lines from the top and bottom 4 link bar. It will be below the ground plane and behind the tire CP on the left rear for example.
excellent reply Chop
Anti squat is a production automobile parameter to try to get some performance out of the grocery getter car design and of little value in a tunable purpose built race car. All you have to know on Rear IC is longer is better.
I suggest you work on mapping the rear end rotation on roll and measure pitch and yaw as well. know how much each link changes the set up and learn WHY. Software on the rear end just uses the lower arm mount points and the older version i have does not address diet car set ups.
RM Thanks for all you do for this forum. There is no other with so much interesting info. I would like to give some of my thoughts on dirt late model suspension. Please refer to the drawing below. This is weight transfer to the rear on straight forward acceleration without consideration to the dampers and a few other forces.
With acceleration we only have to worry about forces from one end of the car, the rear. Unlike decell and lateral G forces which have resisting forces from all four corners. Similarly to lateral there are six major things to consider after the wheel base and the center of gravity height are established. They are the elastometric weight transfer, geometric transfer, which consists of the height of the forward drive force compared to the height of the center of gravity of the sprung mass, the jacking effect of the forward drive force, and the lift of the torque control device on the rear axle. The last is the aero drag height, center, and magnitude, and down force location, and magnitude. On a track that has o lot of speed change in the straight the aero will be the dominating forces at the end and the others will dominate off the turn where the acceleration rate is much higher. All will be varied dynamically with changes suspension height and velocity.
This straight forward acceleration may never happen to some short tracks, especially if you run the inside where the straight is rounded by running up to the wall in the center. We must normally consider a combination of lateral and longitudinal on most parts of the track, which makes things much more interesting.
We know we cannot change the total weight transfer to the rear without changing center of gravity height, wheel base, or acceleration. We cannot change them easily, but we can control, to some extent how much is handled by the left and right rear. On tracks that have a lot of bite you are not off the throttle much at all. On tracks that are low traction you are going from low throttle to high coming off the turn putting the rear suspension through a lot more travel with high anti squat. In that case I think anti squat is very important. That is because as you get on the throttle the mass of the sprung weight is moving away from the track and the opposite reaction is pushing the rear axle into the track. This does not last long, only as the frame is moving up but it does give a head start on the traction cycle. When you hit the throttle there is only static weight on the rear and as the car moves forward weight is transferred to the rear giving more traction and allowing more acceleration. This cycle keeps building off the turn, but can have a head start with anti squat before it starts to accelerate forward.
Aero down force also increases with velocity. With a late model having a high horsepower to weight ratio you can afford to lift that wide body and spoiler as far up in the air as you can, but now that is limited by the rules. Another help in the turns is the high degree of roll of the body which directs the aero down force on an angle, putting more on the inside tire. The late models have gone to a ton of dynamic cross weight by standing on the left trailing arms. That makes a lot of inside weight, traction, and drive. They then use a lot of rear steer to help turn and this also puts the car on an angle to the direction of travel, but the rear wheels more in the direction of travel not breaking traction as much. That helps maintain the forward drive, and also makes the body side panel deflect the air helping resist centripetal force. This setup is geared more to a slick track.
The drawing shows how links and torque arm effect loading on the rear axle and unload the springs with acceleration. The gain in down force on the rear tire is not in addition to weight transfer from acceleration but part of it. The drawing shows a static position, the instant center and force direction and magnitude are changing dynamically and constantly. These are the basic forces, there are more involved.
I think I ran on long enough for one post. Please let me know any opinions on this.
ufo
i got halfway thru your post above, and stopped. was replying to each item but it became readily apparent you have not read thru this long 62 page class. if you had you would have seen my posts addressing each and every aspect you chose to comment on. i suggest you read and revisit your post.
Ranger Mike said:
ufo
One tip for @UFO -- You can use the SEARCH feature in the upper right corner to search just this thread for keywords or phrases. Just pull down the "Everywhere" default for where to search, and change it to "This thread". :smile:
Thanks for the tip Berkeman. That is a cool tool to get around on this forum.
RM, sorry I didn't mean to be repetitive, this is the first time I ever posted on a forum. I'm a slow reader and started reading this a long time ago and also have a good memory, but it's short so I don't remember it all. I did go back and review a few things.
I was just trying to respond to Wylde's post and had other info to help make my point. I also disagreed somewhat with the point that anti squat didn't apply much to racing, I think it does on late models on certain tracks. I didn't expect a response to everything. There were some points that I don't recall seeing in earlier posts like the angle of the side of the car to the travel path, the force change from roll degree, anti squat and traction cycle, distribution of left and right loading under acc., the difference in anti squat effect on a tacky verses a slick track, and dynamic cross weight jacking from standing on the rods.
RM what is your opinion on the center of gravity calculations using the whole car, I think it should be on the sprung mass only. On a solid axle car there is nothing you can do to change the transfer or distribution of the weight of the axles so if you want to know total transfer, they should be calculated separately. This should move the CoG up a little, this is the only mass rotating around the roll center. To get more accurate weight transfer calculations, CoG lateral movement, fuel slosh, and tire spring rate should be considered.
Ignoring the front suspension in acceleration? Tell that to a drag racer.
True.
You seem to think that the fact that the sprung mass is moving, that it is somehow adding some vertical force. It does not. (Any extra vertical force would come from the increase in CG height, which would increase the weight transfer)
You seem to think that the weight transfer is slowly building under a given acceleration. It does not. It is instantaneous. If the acceleration is there, the weight transfer must also be there.
Also, the car doesn't need to move to have a weight transfer. You can have an acceleration at a zero velocity (car stopped) and the weight transfer will be there. Of course, with an acceleration, the car will not be stopped for long.
UFO said:
RM what is your opinion on the center of gravity calculations using the whole car, I think it should be on the sprung mass only. [...] This should move the CoG up a little, this is the only mass rotating around the roll center.
I think this come from the fact that you think that the weight transfer is influenced by the body motion. Again, it is not (other than CG height change). The unsprung mass is accelerated and it will contribute to the horizontal inertial force acting at the CG (creating a moment about the ground, where the equal and opposing traction force lies), which in turn will be compensated by a reaction moment coming from the axles, i.e the weight transfer.
The keyword here is moment. I think @Ranger Mike hates the term weight transfer because ... there is no weight transferred. There is a moment that compensates for (or adds to) the weight supported at each corner.
The fact that the suspension moves is only a matter of knowing in what proportion (% anti-squat, % anti-lift) does the weight transfer goes through the solid links of the suspension or through the unrestricted spring.
thanks Jack, was watching goat screw at Daytona..what a waste..
my hang up is as stated. I hate the term.
Please read post 563 on page 23 on CoG
228 on page 10
470 on page 19
676 on page 28 and
811 on page 33 - this one is my rant on weight transfer!On this post ifin you don't do the homework, you don't get the trophy.
Yeah, no kidding. I gave up after a couple of hours -- looked like the rain would postpone it until today and also give tome for more car repairs...
UFO
Unless you have front or four wheel drive the front is not contributing to forward acceleration. It does enter in with controlling left to right distribution of loads, it has nothing to do with jacking forces from acceleration, which is what the discussion was about.
UFO
You are going to have to talk to Newton about that, the third law of motion goes something like when any object puts a force on another object it will have an equal and opposite reaction on the first object. So when the sprung mass is forced up by the rear the rear will have that same force pushing down on it, and this is in addition to acceleration weight transfer.
UFO
In real life there are very few things that are instantaneous the same here. The acceleration depends on traction, traction depends on load, load from transfer depends on acceleration and so on is the cycle. It also takes time to torsionaly flex the tire, wind up the axle, pitch the sprung mass, and compress and extend the springs and then the traction cycle.
Unless you have an external acceleration or force acting on the car you cannot have weight transfer without movement. The cars acceleration is from engine power put to the wheels, unlike gravity or lateral force from turning, which can act on it without movement if it has a equal resisting force in the opposite direction.
UFO
Well, I think you're wrong again, some of what you said is ok, but you're not looking at everything. The moment about the tire contact patch is only for overturning and geometric forces. The other moment is about the roll center, which the sprung mass CoG is rotating. Here is what's happening, on cars that have a lot of body roll, there can be a lot of lateral movement of the CoG which will transfer weight to the outside (RM this is real weight transfer along with fuel and oil slosh).
Technically weight is the force from gravity only, but most consider how the loads change from the resultant force from gravity and other acceleration forces and call it weight transfer, nothings simple!
Beside the formentioned there is other real weight transfer that is from placing the car on a well banked turn. Put the scales under it and the inside will be heaver.
Me thinks somebody has never seen a car, with the brakes solidly applied, move around when engine power is applied to the drive train. :doh:
There is not only the side-to-side rocking from engine torque, but also, depending on the direction of driveshaft rotation, the front or the back suspension will rise.
UFO
Any Race car driver will tell you, front end lift has to be controlled on acceleration. It is a major tuning point to get the car to hook up.
UFO
This race car suspension class in posted in Physics Forum for a reason. We use the correct terminology to understand how things work or don’t work at the track. Inventing new words or posting non supported opinions is legal here but do not expect an answer.
There are no participation trophies in RACING. Only the winner gets one.
UFO
Obviously did not read the recommended posts I noted.
UFO
Again with the “weight transfer” ..and racers wonder why I keep harping on this myth…
I got to measure all that “real weight transfer” on a full fuel cell and in my dry sump oil pan. Should be huge.
Anyway, you are welcome to comment but we are not compelled to reply.
Hi Tom.G, I am not so sure I know what you are referring to, I guess it's about acceleration forces on a car sitting still. I will try to explain, what I think happens, better. If a car is sitting still out of gear, on scales, and you snap the throttle, with a, from the front, CW rotating engine. The weight on the right side of the car would increase. This is from the opposite reaction of rest of the car twisting it in the opposite direction of the rapidly accelerating rotating mass in the engine. This is short lived. There may also be a slight gain or loss from the cooling fan if turning depending on the direction it is deflected away from the car.
With a solid rear axle, brakes locked, Trans in and output same direction, and full engine torque applied. The axial torque on the rear housing, up in the front, will be engine torque times trans gear ratio times rear gear ratio. The rear would not have any of this axial torque transmitted to the frame. The forward torque of the axle would be canceled by the rearward torque of the housing, all balanced in the rear as a unit, assuming the brake caliper brackets are fastened to the housing and not on floaters.
The other toque transmitted to the rear from the drive shaft twisting the rear down on the left and up on the right. The magnitude of this will be engine torque times the trans ratio of the gear you are in. This, of coarse, has a opposite reaction applied to the frame by the engine, of the same magnitude. This torque lifts the frame on the left and down on the right. Some of the force gained on the left wheel will be taken off the left rear spring and the opposite on the right rear. Only part of the load change at the axle is made up by the spring force from length change. The rest of it is applied to the front springs from frame roll.
The proportion of the torque handled by the front and rear depends on the roll couple distribution between the front and rear. The bottom line is you may have some corner weight change, but the total front, total rear, total left, and total right will be the same as static
I think you forgot about the drive shaft pinion in the rear end climbing up on the now-stationary ring gear.
I once had a motorcycle with a driveshaft that when you popped the clutch, the back of the frame would come up and boot you in the behind! (Kinda tough on the passenger too.)
UFO
Hi RM, That would be nice if we could run a whole race and still have a full tank of fuel, that wouldn't make the guy at the fuel truck happy. I'm sure you know a lot of the Saturday night racers running 25 lap features go out with a half tank of fuel. Let's take a 25 x 20 foot print 40 gal. tank that is half full of alcohol, on a flat track, pulling 1G of lateral force. Well, that's moving 140 lbs 6'' to the right, not only shifting, but carrying some inertia into the right side of the tank. It may even move more then that depending on how high it's mounted and how much roll is happening. That's why you should have slosh control. Yeah, I know that's the extreme in one direction, but your example was in the other. I thought dry sump systems have oil tanks? I know they're narrow and tall and the oil doesn't move much.
RM I don't need a comment on everything. I made some points that may spark some interest, readers can agree or not, they can comment or not, If they disagree, they can state their case and maybe discuss it further. Maybe one of us will change our mind, Isn't that how we can all learn from this forum? Isn't that what it's for?Either way this is a pretty good informative forum and I appreciate all the work you put into it.
I once had a motorcycle with a drive shaft that when you popped the clutch, the back of the frame would come up and boot you in the behind! (Kinda tough on the passenger too.)
Tom .G Hi, I never really got into motorcycle suspension dynamics and don't know how they're linked. It looks like you're popping the clutch to take off. I was talking about having the brakes locked up. Yes, I was the rear rapping up in the front. You have to look at it like the wheel is welded to the end of the axle tube. The axle tube And the axle shaft are trying to rotate in opposite directions and balance each other out which leaves the axle housing not attempting to rotate in either direction. After thinking about it a little more there may be a little movement from the axle twist, relative to how long and thin they are compared to torque applied. I still think the rotation would happen the inside of the axle shaft and the ring gear and the housing will not move
Ranger Mike said:
@UFO
Unless you have front or four wheel drive the front is not contributing to forward acceleration. It does enter in with controlling left to right distribution of loads, it has nothing to do with jacking forces from acceleration, which is what the discussion was about.@Ranger Mike said
I think you guys are missing the point, I never said that the front isn't a valuable tool to get balance and control acceleration, especially coming off a turn when there is still some lateral force. The point was that there is only one end of car supplying torque to the tire and pushing on the track. Sorry for the confusion.
With a drag car I think the car would be faster with the front tires just off the ground, all the weight on the drive tires. And also all of the drive shaft torque on the rear and reaction on the frame would be very close to balanced on the rear tires. The problem is you'll have no control with steering so, better get some weight on the front
whoa up there UF
I have to step in here as you are putting out some dangerous information.
Have you ever been on a race team pit crew?
No experienced round track racer will race with a half full fuel cell. Why. Simply watch video below. In the old days ( 1950s and 1960’s) I saw many a race car explode on impact before fuel cells were required. It is not pretty.
This top off the tank myth , custom or ritual carried over to the fuel cell days but still remains strong on the round track circuit. Drivers are extremely superstitious and just because the fuel cell says it will not explode, don’t mean the racer will believe this.
So he tops it off. You down size the tank to give you the minimum of fuel required to complete the race ( with potential caution laps) and fill it to the top before each race outing.
Todays fuel cell has foam inside the rubber bladder. This foam prevents fuel movement in the bladder and we do not have fuel SLOSH. No way, no how!
I have seen fuel cells catch fire because of metal piercing the cell tub and bladder. Fuel cell life is 4 to 5 years and you have serious safety concerns racing an old bladder. Additionally the foam in the fuel cell will deteriorate and clog your fuel pump and fuel filter.
Who in their right mind would run a 40 gallon fuel cell on a short track 1/3 mile 20 lap race? Nascar has 17.5 gallon fuel cell limit for DAYTONA! Most local race tracks have 22 gallon maximum limit on fuel cells.
Most Saturday night warriors will run a 8 gallon to 15 gallon fuel cell depending on if they run an occasional ½ mile track. A 20 gallon cell is too big and a waste of space.
Where you going to mount this 40 gallon monster? Where you going to race it?
Ranger Mike said:
whoa up there UF
RM If you read to the bottom it said it was the extreme, that's not dangerous it's more like history. I don't know who is running 40 gal. tanks today, but back in the day it was commonplace with at least the northeast Modifieds. They were poly tanks, called drop tanks because they were L shaped and dropped down behind the rear. They were mostly used for alcohol. I think today there is a lot of 24 gal. fuel cells in use, but some tracks don't require them, at least for alcohol. The foam in the tank doesn't let the fuel hit the side and bounce back, but the fuel still moves to the side, just takes a little longer to get there, it dampens the flow
I still don't understand your point about filling your tank and not running it half full. If you use a half tank of fuel in a race, you start out with a full tank at the end your running it half full. If you fill it up half way your running it half full in the beginning and empty at the end. No one I know puts more fuel in then they need for the race, unless the need some to make weight. And that's not done much because it is better to locate lead ballast where it is most needed for chassis tunning.
As for your question, the answer is yes.
