Where Am I Going Wrong in Finding Radiation from an Oscillating Dipole?
samjohnny
2. Homework Equations [/B]
Given in the question.
[/B]
For part a I obtained an expression for the the dipole moment:
##P(t)= P_0 cos(wt)##
And therefore, for part b, I obtained the expressions
##\frac{dP}{dt} = -wP_0 sin(wt)## and ##\frac{d^2P}{dt^2} = -w^2P_0 cos(wt)##.
Now when I make use of Eq. 1.39 to obtain ##E_\theta## for part c), I substitute in the above expression for ##\frac{d^2P}{dt^2}##, but end up with the cos term being ##cos(wt)## from ##\frac{d^2P}{dt^2}## as opposed to ##cos(kr-wt)## which is required. Not sure where I'm going wrong.
In Eq. 1.39, the square brackets in the numerators denote a condition on the time at which you evaluate the quantities inside the brackets. Check your notes or text for details.
Ah I believe that the derivatives must be evaluated at the retarded time, is that correct?
Yes.
Likes samjohnny
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
