Random Thoughts 7
- Thread starter Evo
- Start date
2,049 replies · 98K views
pinball1970
2025 Award
- 3,867
- 6,204
55 years this week Apollo 11 landed on the moon. With all the Space x crazy stuff plus the first Ariane 6 launch I wanted to compare footage.
Even today the 1969 footage is really amazing. The fact it is slow motion just adds to the coolness.
See the amount of debris? Wow.
Anyway, not worth a thread but certainly worth a mention.
Apollo 11
Space x last month.
Ariane 6 last week
Apollo 11
Space x last month.
Ariane 6 last week
Staff Emeritus
2025 Award
- 22,679
- 7,766
What to do when your internet goes down while traveling
https://finance.yahoo.com/news/what...rnet-goes-down-while-traveling-174617112.htmlSome good advice. Plan ahead.
Staff Emeritus
2025 Award
- 22,679
- 7,766
Every year, scores of boaters travel the 6,000-mile route around the Eastern United States.
https://www.atlasobscura.com/articles/loopers-great-loop-experience
I think retracing the Lewis and Clark expedition would be a great adventure.
The Great Loop has been called the last great adventure in North America, a 6,000-mile journey from the Mississippi River to the Gulf Intracoastal Waterways, around Florida and then up the Atlantic coast, across the Erie Canal, and through the Great Lakes. In 2022, only 227 boats returned to their point of origin, “crossing their wake” and earning the privilege of flying the gold Great Loop burgee (flag). Most “Loopers,” traveling in boats at least 30 feet long, took about a year to complete the route. Omaha Nebraska’s Mike Straub completed the loop in just 91 days. He did the whole thing on a Sea-Doo jet ski.
OmCheeto
- 3,643
Anyone know how to interpret a 'perimeter acre'?
Plugging in the numbers from the above fires, I get an R² of 1.000 for a quadratic function: y = 2.1122x² +264.07x -474.36
where y is 'perimeter acres' and x is the perimeter, in miles.
| Perimeter Acres | 133,489.06 |
| perimeter | perimeter acres |
| 1.14 | 179.5 |
| 3.86 | 226.09 |
| 4.4 | 701 |
| 50.82 | 18432.12 |
| 147.43 | 84364.39 |
docnet
- 796
- 487
A perimeter acre is probably defined asOmCheeto said:Anyone know how to interpret a 'perimeter acre'?
Perimeter Acres 133,489.06
perimeter perimeter acres 1.14 179.5 3.86 226.09 4.4 701 50.82 18432.12 147.43 84364.39
$$\frac{\text{length of the wildfire's perimeter}}{\text{area of wildfire}}.$$
- 2,230
I'm guessing that "perimeter acres" means the area (near the perimeter) that is actually on fire, assuming the area in the middle is burnt out.
Then the average width of the burning area is approximately the "perimeter area" divided by the "perimeter length" (assuming the width is a lot smaller than the length).
The values seem plausible.
(For readers outside the UK and US, a yard is about one metre.)
| Name | Perimeter length ##p## miles | Perimeter area ##a## acres | Estimated perimeter width ##a/(640p)## miles | Converted to yards ##\times 1760## |
| Lemolo | 2.14 | 179.5 | 0.13106 | 231 |
| Ore | 3.86 | 226.09 | 0.09152 | 161 |
| Trail | 4.4 | 701.38 | 0.24907 | 438 |
| Larch Creek | 50.82 | 18432.1 | 0.56671 | 997 |
| Lone Rock | 147.43 | 84364.4 | 0.89411 | 1574 |
Homework Helper
- 7,887
- 13,197
Seems not to be defined at x=1, where you get a negative value.OmCheeto said:Anyone know how to interpret a 'perimeter acre'?
- 20,819
- 28,467
And I thought it as a little place behind the house.DrGreg said:(For readers outside the UK and US, a yard is about one metre.)
- 20,819
- 28,467
Must be Chihuahuas if it is limited to 91 cm.WWGD said:With two dogs in it.
OmCheeto
- 3,643
So it's 1/length? Length is like wavelength, and 1/wavelength is frequency, so....docnet said:A perimeter acre is probably defined as
What's the frequency, Docnet?
I agree, that this seems like a plausible answer.DrGreg said:I'm guessing that "perimeter acres" means the area (near the perimeter) that is actually on fire, assuming the area in the middle is burnt out.
Name Perimeter length
p milesPerimeter area
a acresEstimated perimeter width
a/(640p) milesConverted
to yards
×1760Lemolo 2.14 179.5 0.13106 231Ore 3.86 226.09 0.09152 161Trail 4.4 701.38 0.24907 438Larch Creek 50.82 18432.1 0.56671 997Lone Rock 147.43 84364.4 0.89411 1574
But I suspect it is wrong.
I loosened up my Google search parameters and discovered this PDF of a 1976 document, where I found on page 64:
Figure 7.--Approximate
area of wind-driven
fires, using Anderson's
double-ellipse formulae
in appendix II. In
this figure, the area within the approximate
perimeter (acres) has
been divided by the
squared distance (in
chains) from the point
of origin to the head
of the fire. Thus,
this ratio decreases with windspeed while
the area itself actually increases.
where they use 'chain' as a unit of measure, and Anderson's double-ellipse formulae in appendix II looks to be a rabbit hole of maths.
At least it didn't include the square root of negative 1.WWGD said:Seems not to be defined at x=1, where you get a negative value.
In any event, never mind.
docnet
- 796
- 487
The quantity perimeter/(surface area) is just a concrete measure of... perimeter per surface area (sorry for the redundancy, but it was so self-explanatory that I'm just so puzzled with your question.OmCheeto said:So it's 1/length? Length is like wavelength, and 1/wavelength is frequency, so....
If it helps, the quantity could be loosely interpreted as the "oscillation count" of the perimeter to measure how "wavy" or "curvy" the perimeter is. But there is probably no benefit in defining it using frequencies and wavelengths. The quantity would have a minimum value (corresponding to a circle) and no maximum value (corresponding to certain fractals).
In any case, it may not be the right interpretation of the data, continuing this tangent may not be helpful. I was just trying to offer an alternative.
Mentor
- 15,796
- 10,682
jack action said:
- At 18, they ask for 5-year experience;
- At 50, you are too old to work;
- At 62, you are too young to retire.
So true, to complete the story:
- I notified management on April Fool's that I plan to retire on May 1st
- I retired on May 1st and
- I got to exclaim May Day! May Day!
As so many retirees don't know what to do in the days following retirement.
Retirement is NEVER what you expect it to be.
pinball1970
2025 Award
- 3,867
- 6,204
I may try being a rock star full time.jedishrfu said:As so many retirees don't know what to do in the days following retirement.
- 20,819
- 28,467
Honestly?pinball1970 said:I may try being a rock star full time.
I wish you all the best and seriously hope you will!
I mean, if Taylor can.
- 19,385
- 15,622
Crowdstrike provides security add-on to Windows for businesses, not personal computers. Are you a business? Do you pay them to provide their service to you?WWGD said:Crowdstrike, anyone? Ive yet to look at my computer. ( Assuming people who have more than one OS installed).
pinball1970
2025 Award
- 3,867
- 6,204
A little tongue in cheek yes, BUT there would be no more restrictions on practice and gigs.fresh_42 said:Honestly?
If we have a gig in London or Scotland we have to set off 12ish so I have to book days off.
Certainly make things easier that way.
EDIT: The bassist is 68 and seems relaxed with his retirement and still doing music. Hopefully I can find similar.
Homework Helper
- 7,887
- 13,197
Yes, he can jerk about global warming while touring the globe solo in his mega jet. Taylor did it.fresh_42 said:Honestly?
Leason. Be more like Roger Taylor, not the other one.
pinball1970
2025 Award
- 3,867
- 6,204
We all manage to fit in one van for gigs so the planet is safe from me!WWGD said:Yes, he can jerk about global warming while touring the globe solo in his mega jet. Taylor did it.
- 20,819
- 28,467
Homework Helper
- 7,887
- 13,197
I haven't had a car in a while. My gas is the only contributor. I see people avoid me, but only within a 100ft radius.pinball1970 said:We all manage to fit in one van for gigs so the planet is safe from me!
Edit: Just please leave the van. Down by the river!
pinball1970
2025 Award
- 3,867
- 6,204
https://phys.org/news/2024-07-elon-musk-spacex-headquarters-california.htmlWWGD said:Musk moving X and Space X from California to Texas.
pinball1970
2025 Award
- 3,867
- 6,204
It is a horrible, ugly, uncomfortable, old thing but we love it. Even when It broke down in Macclesfield when we had a gig in Derby! It is a re-done UK Royal mail van. We only take two vehicles if we are also supplying the PA as well.WWGD said:I haven't had a car in a while. My gas is the only contributor. I see people avoid me, but only within a 100ft radius.
I took this from vehicle 2 on way to Lakes.
What is the newest installment of 'Random Thoughts' on Physics Forums?
- Evo
- · Replies 11K ·
- Other Physics Topics
- Replies
- 11K
Random thoughts thread while microwaving dinner
- skyshrimp
- · Replies 5 ·
- Replies
- 5
High School Random thoughts on Fibonnacci sequence
- parshyaa
- · Replies 4 ·
- General Math
- Replies
- 4
How do random thoughts come to our mind?
- Raghav Gupta
- · Replies 8 ·
- Biology and Medical
- Replies
- 8
Random thoughts on Maxwell's demon
- ThomasT
- · Replies 25 ·
- Electromagnetism
- Replies
- 25
High School My random thoughts about the sun, black holes, and gravity.
- Cait
- · Replies 1 ·
- Astronomy, Astrophysics, Cosmology
- Replies
- 1
Undergrad Thoughts about this Bayesian Mechanics paper?
- Fra
- · Replies 3 ·
- Quantum Interpretations and Foundations
- Replies
- 3
COVID Booster Shots - Thoughts/News?
- kyphysics
- · Replies 52 ·
- Replies
- 52
Other Your thoughts about "International Journal of Theoretical Physics"
- EternalStudent
- · Replies 1 ·
- STEM Academic Advising
- Replies
- 1
Undergrad Random thought about force and motion
- tadpole
- · Replies 7 ·
- Mechanics
- Replies
- 7
