Random Thoughts 7
- Thread starter Evo
- Start date
2,061 replies · 124K views · last reply
- 28,467
I watched a documentary about Stonehenge.
Stones here, stones there, how where they transported, where from, stones everywhere. However, the only really interesting question would be how they could afford it. Where did they take energy and time from? I don't care about the stones, I want to know where they get the resources from, not the stones.
I watched a documentary about castles.
It is always about sieges, tunnels, conquering those things, weapons, and so on. Who cares? I want to know why the conquerors didn't let the castle be a heap of ugly stones and occupied the land instead. Why bother a siege? Simply ignore that thing! Why wasn't that ever a possibility?
- 13,939
- 16,855
If you want to go past the castle, your logistical support may have to go back and forwards past it and be subject to raiding from the castle. If there are significant numbers of troops inside they may raid your army (and/or your supplies) from the rear at the same time as you are engaging somebody in front of you. Or they may simply note that you and your army are no longer between them and your country, which might be bad. And if you want to occupy the land you need to do so in sufficient numbers that your garrisons are all strong enough to make a go at resisting a raid from the castle, or small garrisons will get picked off one by one. In short, the problem isn't really the castle so much as the fact that it's a shelter for enemy armed forces.fresh_42 said:Simply ignore that thing! Why wasn't that ever a possibility?
Also, you may be after killing or capturing whatever's inside the castle. If you want to take the other guy's land you might want the citizens to work it - in which case your aim is not to kill too many of the citizens, just the armed forces in the castle. Or the king (or whoever) might be in there.
But if it's not defending anything you want right now and you aren't too worried about whatever the garrison might try, sure you can just ignore it. The Maginot Line during World War 2 is a modern example of doing just that - both sides largely just went round it in their offensives.
- 20,819
- 28,467
It doesn't cost a lot of troops to control breakouts through at most two openings and often surrounded by a moat. I simply change the aim of a siege with significantly fewer men and command the rest of them to deal with landlords where food and money are generated. It makes no sense to concentrate on locations that are basically already prisons.
Homework Helper
- 7,920
- 13,238
Thought @pinball1970 would like this:
https://americansongwriter.com/the-...-that-made-the-best-of-an-eventful-road-trip/
Mayhem
- 455
- 335
Mein Gott. I should have gone into engineering. Higher salary increase after 10 years (compared to academic chemistry) and and 1-2 years less school time.
Oh well, if I do a Ph.d it will be worth it anyway.
- 20,819
- 28,467
Whenever I think about, research, or otherwise encounter historical events, facts, or discoveries, I have to think about what a German astronomer said on TV:
I think we should keep this in mind.The people from ten thousand years ago weren't so much different from us. They have had the same capabilities and mental awareness as us. Biology didn't evolve so much during that relatively short period. All that changed is our technological evolution and our ways of sharing information.
Homework Helper
- 7,920
- 13,238
I would say the increase in "Entropy/Mess" in a room from day to day is sublinear. If I clean on Sundays, but not on Monday, it won't be ( at least)twice as messy on Tuesday than it was on Monday. If I don't clean it on Monday nor Tuesday, it won't be 3x as dirty on Wednesday as it was on Monday, etc. It seems cleaning twice a week would minimize time/effort while keeping the room in reasonable condition.
- 20,819
- 28,467
And how long did it take you to calculate ##\log_2 5## by hand?WWGD said:Kind of surprised to see this ( alleged?) problem in the entrance exam for Cambridge Math program: Find ##x## if ##8^x+ 2^x =130## . It took me all of 2 minutes to figure it out. Just use that ##8=2^3##.
Homework Helper
- 7,920
- 13,238
I doubt you're required to. A Taylor series would likely give you a good approximation. Since ##2^2=4; 2^3=8## , it is closer to ##2## than to ##5##. Use the derivative for a tangent line approximation.fresh_42 said:And how long did it take you to calculate ##\log_2 5## by hand?
- 20,819
- 28,467
Power series can be nasty. You need half a googol steps to calculate ##\pi=4\tan^{-1}(1)## up to ##100## digits from the standard power series, and ##90## with a simple trick.WWGD said:I doubt you're required to. A Taylor series would likely give you a good approximation. Since ##2^2=4; 2^3=8## , it is closer to ##2## than to ##5##. Use the derivative for a tangent line approximation.
Homework Helper
- 7,920
- 13,238
Not to compute the Taylor series for ##Log_2 x## about ##5##. Are you sure they require anything beyond Edit:##ln(5)/ln(2)##?fresh_42 said:Power series can be nasty. You need half a googol steps to calculate ##\pi=4\tan^{-1}(1)## up to ##100## digits from the standard power series, and ##90## with a simple trick.
- 20,819
- 28,467
I was joking.WWGD said:Not to compute the Taylor series for ##Log_2 x## about ##5##. Are you sure they require anything beyond Edit:##ln(5)/ln(2)##?
But the example with ##\pi## is true. It is amazing how a little trick can reduce the necessary steps so dramatically. #7 in
https://www.physicsforums.com/threads/math-challenge-december-2020.996697/
- 13,939
- 16,855
I think you're off by two orders of magnitude and a unit change. I make it ##365×24×3600×3×10^8\mathrm{m}## is 9.4608 trillion kilometres, or about 5.913 trillion miles.WWGD said:Ok, not too hard to remember: a light year is 946 trillion milles , plus 80 million miles, i.e., 946.080.000.000
Homework Helper
- 7,920
- 13,238
Ah, I guess I thought the speed of light was given in miles/second. I'm remembering now it is 186,000 miles/sec, not 300,000 miles/sec.Ibix said:I think you're off by two orders of magnitude and a unit change. I make it ##365×24×3600×3×10^8\mathrm{m}## is 9.4608 trillion kilometres, or about 5.913 trillion miles.
So Ill settle for 946 trillion km + 80 million Km. Then I use that 1 mile~1,609 metres. Or metres jn UK ish.
Homework Helper
- 7,920
- 13,238
As a " meta point" of sorts, these casual exchanges can be valuable. This one allowed me to correct my knowledge base.WWGD said:Ah, I guess I thought the speed of light was given in miles/second. I'm remembering now it is 186,000 miles/sec, not 300,000 miles/sec.
- 13,939
- 16,855
That's 100ly, though.WWGD said:So Ill settle for 946 trillion km + 80 million Km.
There are approximately ##\pi\times 10^7\mathrm{s}## in a year and ##c=3\times 10^8\mathrm{ms^{-1}}##, so one light year has to be approximately ##10^{16}\mathrm{m}=10^{13}\mathrm{km}##, so about ten trillion, not a thousand trillion.
- 20,819
- 28,467
I get dizzy. How can you talk about trillions when you are from countries that define it differently?
- 13,939
- 16,855
If we differed by three orders of magnitude, I'd agree. I think pretty much everybody uses the American standard now anyway. Despite it making less sense.fresh_42 said:I get dizzy. How can you talk about trillions when you are from countries that define it differently?
Oh dear...WWGD said:This source cites it as ##9.46 \times 10^{12}##km. I saw it computed in a YT short and dIdnt double-check.
One hour is 3600 seconds
One day is 24 hours
One year is 365 days
That makes one year 31,536,000 s
The speed of light is 300,000,000 m/s
That makes one light year 9,460,800,000,000,000 m (##9.5\times 10^{15}\mathrm{m}##), or ##9.5\times 10^{12}\mathrm{km}##.
- 20,819
- 28,467
You mean ##6## as in ##10^{12}## (US) versus ##10^{18}##?Ibix said:If we differed by three orders of magnitude, I'd agree.
https://de.wikipedia.org/wiki/Lange_und_kurze_Skala#Vergleich_der_Skalen
Definitely not here, and I cannot see that anyone quit using -iards.Ibix said:I think pretty much everybody uses the American standard now anyway.
Sorry, I thought the British would have used the European standard.
- 16,855
Well, any power of ##10^3## difference rings "maybe it's a mega/giga/tera mix up" alarm bells for me, but yes you're correct here.fresh_42 said:You mean ##6## as in ##10^{12}## (US) versus ##10^{18}##?
I think the battle in English was lost long ago. The only "normal" usage of such values is financial, and that seemed to settle on the US standard when I was a kid.fresh_42 said:Sorry, I thought the British would have used the European standard.
- Evo
- · Replies 11K ·
- Other Physics Topics
- Replies
- 11K
- skyshrimp
- · Replies 5 ·
- Replies
- 5
High School
Random thoughts on Fibonnacci sequence
- parshyaa
- · Replies 4 ·
- General Math
- Replies
- 4
- Raghav Gupta
- · Replies 8 ·
- Biology and Medical
- Replies
- 8
- ThomasT
- · Replies 25 ·
- Electromagnetism
- Replies
- 25
- Cait
- · Replies 1 ·
- Astronomy, Astrophysics, Cosmology
- Replies
- 1
- Fra
- · Replies 3 ·
- Quantum Interpretations and Foundations
- Replies
- 3
- kyphysics
- · Replies 52 ·
- Replies
- 52
- EternalStudent
- · Replies 1 ·
- STEM Academic Advising
- Replies
- 1
Undergrad
Random thought about force and motion
- tadpole
- · Replies 7 ·
- Mechanics
- Replies
- 7
