Random Thoughts 7
- Thread starter Evo
- Start date
2,056 replies · 117K views
- 28,467
I once coded in an IDE that used French, English, or both. You could type, for example, "IF ... ALORS ..." or "SI ... THEN ..." without any problems.TensorCalculus said:I somehow only just realised that programming languages are all "in English" - like they use English words for syntax (e.g. if)
TensorCalculus
2025 Award
- 283
- 469
What did you use? I am curious nowfresh_42 said:I once coded in an IDE that used French, English, or both. You could type, for example, "IF ... ALORS ..." or "SI ... THEN ..." without any problems.
- 20,819
- 28,467
https://windev.com/TensorCalculus said:What did you use? I am curious now![]()
I sometimes decided according to which one is shorter to type. E.g., "sablier" is shorter than "hourglass".
TensorCalculus
2025 Award
- 283
- 469
Whoa - so cool! I never knew that existed. Might give it a try at some point just for fun
- 20,819
- 28,467
It is very focused on the UI part of programming, and code is usually behind "buttons", "tables", or similar UI features. But, yes, it is really faster and more intuitive to produce applications. I think it produces C++ code internally, but you don't see it. The IDE is basically UI stuff with code lines that look like Visual Basic.TensorCalculus said:Whoa - so cool! I never knew that existed. Might give it a try at some point just for fun
TensorCalculus
2025 Award
- 283
- 469
That's very interesting (and quite unique)! Is it widely used?fresh_42 said:It is very focused on the UI part of programming, and code is usually behind "buttons", "tables", or similar UI features. But, yes, it is really faster and more intuitive to produce applications. I think it produces C++ code internally, but you don't see it. The IDE is basically UI stuff with code lines that look like Visual Basic.
(I'm not going to try it because it costs money
)- 20,819
- 28,467
According to their list of customers, yes, but I'm not so sure.TensorCalculus said:That's very interesting (and quite unique)! Is it widely used?
Doesn't it have a test version anymore?TensorCalculus said:(I'm not going to try it because it costs money)
Here is what it typically looks like:
For example:
with the button code line
Static1=Edit1^2
took literally seconds. The watermark is due to the test version I used. It has also its own database, but is also compatible to most existing ones. What I really like about it is, that you can setup language versions: the UI, i.e., button titles, help texts, etc. can be arranged to use dozens of languages between you can switch.
TensorCalculus
2025 Award
- 283
- 469
Nope, no more test version I don't think. But this seems so easy to use! I never knew things like this existed, that's really interesting, thank you!fresh_42 said:According to their list of customers, yes, but I'm not so sure.
For example:
Static1=Edit1^2
(BTW keep your eyes on the Fermat's last theorem page - a lot of rings and headaches later, I am close! I think.)
- 20,819
- 28,467
TensorCalculus said:Nope, no more test version I don't think. But this seems so easy to use! I never knew things like this existed, that's really interesting, thank you!
https://windev.com/windev
TensorCalculus
2025 Award
- 283
- 469
Oh, I am blind, then I will try it out!
- 20,819
- 28,467
You aren't allowed to use it for commercial reasons, of course, but it is sufficient for a try and private "quick-and-dirty" applications. Of course, the work starts if you want to pimp it with proper titles, different layouts, or whatever makes an application user friendly. Their web version is a bit nasty since they use an AJAX architecture, but their mobile version is nice. I once programmed a little app for my cellphone that counted the time during which I didn't smoke.TensorCalculus said:Oh, I am blind, then I will try it out!
Hornbein
- 3,397
In western Colorado in about 1969 I saw a roadside sign for a mine where the customer could breath air that contained radon. It was quite a ramshackle sign though so it appeared not to be a going concern.Borg said:I just saw the first episode of Hazardous History with Henry Winkler. So many memories of my childhood like lawn darts and things that I had never heard of before like the radiation lab for kids with real uranium and roller coasters that subjected people to 12Gs. Wow.
Hornbein
- 3,397
I often think on similar lines.BillTre said:
In Corvallis Oregon there is a set of streets named after the presidents, in order. When looking for an address one could ask oneself who came first, Polk or Garfield? This is however better than the Japanese system for street names. At this moment I am in a place that shares its address with two other buildings three blocks away. This is accessed by walking through a long parking lot then entering a tiny unmarked opening in a chain link fence.
Hornbein
- 3,397
I don't get it.Ibix said:Mr & Mrs Lamb who called their son Sean
Hornbein
- 3,397
I thought it was Shawn. But I've never been to Ireland.Bystander said:"Shorn?"
- 13,926
- 16,811
There are a couple of fairly well known guys called Sean.Hornbein said:I thought it was Shawn. But I've never been to Ireland.
Hornbein
- 3,397
Well duh. Aren't we discussing the pronunciation?Ibix said:There are url=https://en.wikipedia.org/wiki/Sean_Connery]a couple[/url] of fairly well known guys called Sean.
- 13,926
- 16,811
Sure. I was just surprised you seemed to have managed to make it this far through life without hearing either of those gentlemen's names spoken. Or perhaps I misunderstood your comment.Hornbein said:Well duh. Aren't we discussing the pronunciation?
- 13,926
- 16,811
Well, if Hugh Juan to relax it Hugh can.WWGD said:If you relax the term , it's likely the world's most popular name: Sean, John, Ian, Juan, Jean, Ivan,....
- 5,262
I have an unfinished bathroom on the lower floor of my house that we use to store stuff. We call it the garbage room. The gods have decreed that we clean out the room by allowing water to find a way into the back of the room during the heavy downpours that we've been getting lately. The only way to figure out where the water is coming from is to empty the room...
Mayhem
- 441
- 326
"Relax the term" gave me traumatic flashbacks to quantum classes.WWGD said:If you relax the term , it's likely the world's most popular name: Sean, John, Ian, Juan, Jean, Ivan,....
Mayhem
- 441
- 326
Popular diet science is so hacky.
I think that if you took the average of all popular nutritional advice, you'd find you shouldn't eat anything and that carbon is a major predictor of unhealthy food.
So silly. Eat.
So silly. Eat.
Staff Emeritus
2025 Award
- 22,714
- 7,806
Windsurf was a startup Cinderella story. Now it's become a cautionary tale.
https://www.businessinsider.com/peo...d-windsurf-has-set-dangerous-precedent-2025-7
Windsurf, an AI coding company, was on the verge of being acquired by OpenAI for $3 billion, the kind of windfall startup employees dream of. But the blockbuster deal fell apart at the last minute, setting off a whirlwind of last-minute negotiations that left employees in the dark about their future.
The end result — a company split in two with its CEO and top talent getting bought out for far more than the rest of its employees.
Discussions with OpenAI fizzled, and there was a new suitor: Google. But instead of acquiring Windsurf, Google said it would pay $2.4 billion to hire its CEO and top talent and license the company's intellectual property. The hundreds of employees who remained at Windsurf were left adrift until last Monday, when Cognition sent a life raft in the form of buying what remains of the company.
- Evo
- · Replies 11K ·
- Other Physics Topics
- Replies
- 11K
- skyshrimp
- · Replies 5 ·
- Replies
- 5
High School
Random thoughts on Fibonnacci sequence
- parshyaa
- · Replies 4 ·
- General Math
- Replies
- 4
- Raghav Gupta
- · Replies 8 ·
- Biology and Medical
- Replies
- 8
- ThomasT
- · Replies 25 ·
- Electromagnetism
- Replies
- 25
- Cait
- · Replies 1 ·
- Astronomy, Astrophysics, Cosmology
- Replies
- 1
- Fra
- · Replies 3 ·
- Quantum Interpretations and Foundations
- Replies
- 3
- kyphysics
- · Replies 52 ·
- Replies
- 52
- EternalStudent
- · Replies 1 ·
- STEM Academic Advising
- Replies
- 1
Undergrad
Random thought about force and motion
- tadpole
- · Replies 7 ·
- Mechanics
- Replies
- 7
