Ranking Electric Potential of Electrons in a E Field
The discussion revolves around ranking the electric potential changes for an electron moving between two points in a uniform electric field. The correct ranking is B then A, as moving with the electric field decreases electric potential, while moving against it increases potential. The distinction between electric potential and electric potential energy is emphasized, clarifying that potential is defined independently of the test charge. Understanding that electric fields point away from positive charges and toward negative charges aids in visualizing potential differences. This foundational concept is crucial for accurately solving problems related to electric fields and potentials.
Dgray101
Note this is a PRACTICE midterm problem. Not due for homework or for a grade. My exam is on Tuesday
"an electron moves from point A to point B in a uniform electric field as show below. Rank the electrons in diagrams 1 through 2 by the changes in potential from greatest to least when traveling from A to B"
I can't attach an image but it's VERY straight forward.
Answer A Answer B
--------------------> (Direction of E field) --------------->(Direction of Efield)
Point A Point B Point B Point A
The distances are the same. Just swapped.
V = U/q
My reasoning was (A then B) because in the first diagram, we must do work against the electric field, increasing the potential energy of the electron, therefor increasing the electric potential. The converse is true for part B, we move in the direction of the force and so the potential energy of the electron decreases, and so should the electric potential. I am messing up the concept somewhere along the road because the answer is actually B then A.
I think I have answered the question but I need validity. The reason that the potential from B is more then the potential at A is because Electric Potential is defined independent of a test charge. So as you go with the electric field, regardless of the charge, you go to lower values of electric potential. If you go opposite the electric field, you go to values of HIGHER electric potential regardless of the charge.
Welcome to Physics Forums.
Yes, you're reasoning (in post #2) is correct. It's important to remember that electric potential and electric potential energy are not the same thing.
The way I think of it is to remember that E-fields point away from positive and toward negative charge, and the potential is higher around a positive charge and lower around a negative charge. Your reasoning in post #1, if applied to a positive (test) charge, is also a good way to think of it.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
