Engineering RC circuit analysis using oscilloscopes
The discussion focuses on analyzing an RC circuit using an oscilloscope to determine unknown resistance and capacitance values. The user describes their approach of comparing voltage drops between two channels on the oscilloscope and applying Ohm's Law to calculate current and impedance. They express uncertainty about whether the phase angle derived from the impedance comparison accurately reflects the RC component's characteristics. A request for clarification on the circuit diagram is made, suggesting a need for visual aid to better understand component connections. The conversation emphasizes practical application of circuit analysis techniques in a laboratory setting.
blueincubi
this was a practical examination given to us.
[connected to CH1]
|----(1.8k ohms)-----|
|aaaaaaaaaaaaaaaaaa|
|aaaaaaaaaaaaaaaaaa(unknown resistance) [these 2 unknowns are ch2]
(~)aaaaaaaaaaaaaaa|
|aaaaaaaaaaaaaaaaa(unknown capacitance)
so you've got a signal generator which is covered up, and the components are hooked up to the oscilloscope in the manner described above. the problem was to find out the the values of the unknown resistor and capacitor using the graph in the oscilloscope.
2. Equations
t/T = x/360
where:
t is the horizontal distance between the two curves
T is period
x is the angle
Ohm's law
what i tried to do was to compare the voltage drop between ch2 and ch1 (which i treated as two separate impedances). and then divided it by the known R to get a value I which is the current for the whole mesh(?).
using that value I, i obtained the magnitude of the impedance of the RC component by Ohm's Law.
for the angle of the impedance, i compared the phase difference between the pure R impedance and the RC impedance. this is the part I am not sure of, is the angle x i get be the angle of the RC impedance (since purely resistive impedances are 0degs)?
but then, i assumed that the above were correct and managed to get a form a + jb, where j is sqrt(-1), so i took it as the a being the value of the resistor and b as the value of the capacitor?
I don't understand your diagram.
Is it like this:
[PLAIN]http://dl.dropbox.com/u/4222062/R-R-C.PNG
If so, maybe you could just refer to this diagram and say where the components connect to, or, you could modify the diagram using MS Paint and repost it?
10K
