What Happens When a Magnet Approaches a Solenoid?
  • Thread starter Thread starter nblu
    Magnets Solenoid
When a magnet approaches a solenoid, the interaction depends on the polarity of the magnet and the solenoid's magnetic field. If the North pole of the magnet approaches the North pole of the solenoid, they will repel each other, while a South pole would attract. The solenoid's magnetic field strength is influenced by the number of turns per unit length; a tightly wound solenoid produces a stronger magnetic field. The discussion emphasizes the importance of considering the solenoid's winding and the magnet's polarity in predicting their interaction. Understanding these principles is crucial for accurately explaining the behavior of magnets and solenoids.
nblu
Hello, I was doing some questions and I thought I was understanding solenoids and magnets in incorrect way..
The question was, what would you feel if you bring a magnet close to a solenoid. I've wrote 2 possibilities, first is that they will repel and the second is that the solenoid would shoot-out the magnet. I was thinking that if the coil on solenoid is loosely wound, the field lines within the coil are curved so it will repel.. but if it is tightly wound, the field becomes straighter and it will react more aggressively..
I've wrote down my ideas but wasn't really happy with what I've wrote..
Could anyone please direct me to a better answer? Thank you in advance.
Your two possibilities are correct, but that would depend on whether you are bringing the North pole towards the north of the solenoid (remember how to find the direction of the magnetic field when a current is flowing?) and so forth.and the magnetic field of a solenoid is given by B=\mu n I where n is the no. of turns per unit length. If you wind the solenoid more tightly, n will increase and so will B and vice versa.
Thank you rockfreak, for your comment. I'll make sure that I mention the polarity as well when I explain. :)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
