Calculating the Speed of a River Current Using Relative Velocity
To calculate the speed of a river current using relative velocity, the boat must adjust its velocity to cross straight across the river, which is influenced by the current. The initial attempt to solve the problem involved using the cosine function, but the result was incorrect due to a sign error and possibly a misunderstanding of the problem's wording. Clarification is needed on whether the current flows directly from west to east and if the boat's velocity is accurately stated as 119.38 units. An interactive method was suggested, where adjusting the boat's velocity vector can help determine the current's speed. Ultimately, the correct calculation for the current's speed was found using the formula 136.84/tan(angle).
AnkhUNC
I have a boat trying to cross a river with a current flowing ->
The boat is attempting to make it straight across (90d). In order to do this I have to change the volocity to 119.38 and the angle to 100.3.
So what is the speed of the current?
I tried solving using: cos(100.3) = -current/119.38
So -current = -21.345 but this is incorrect. Can anyone help?
You're off by a minus sign and perhaps a significant digit. In terms of the velocity of the current, -V_c = -21.345; thus, V_c = 21.345 to the right. In terms of speed, that's the magnitude of the velocity, always a positive number.
Its still saying its wrong. It was the speed of the current but I thought that's what I was getting.
How is the problem worded? Is the current flowing exactly west to east, parallel to the x axis? Is the boat's velocity given as exactly 119.38 units? What do you mean when you say you had to 'change' the velocity to 119.38?
Objective:
Your task is to set the velocity of the boat so that it travels straight across the river. From the selected boat velocity, you can then compute the speed of the current.
Instructions: (The little white spots are floating in the current.)
(1) Drag the blue arrow tip to set the velocity of the boat relative to the water.
(2) Press START to begin crossing the river.
(3) If the boat misses the dock, press RESET to begin again with the same current.
(4) You can select a new random value for the current with the NEW VELOCITY button.
(5) When you have found the necessary boat velocity vector, use it to figure out the speed of the current. Enter your calculated value in the box labeled “current” below. Press the CHECK button to check your answer.
(6) Keep trying until you get it right*, then press the SUBMIT button to record your score. Only one submission is allowed, but that’s enough, since you shouldn’t submit until you have it right.
* For your answer to be excepted, it must be within 5% of the correct answer.Its an interactive learning thing.
136.84/tan(angle) worked :P
Thanks for the attempt at helping, much appreciated!
