Relative Velocity Q: An Airplane Flying 35° N of E in 100 km/h Wind
In summary, the conversation discusses a question about relative velocity involving an airplane and a steady wind. The question asks for the direction the plane should head, and the answer is given as 42.9 degrees north of east. The conversation includes attempts at solving the problem using a diagram and a system of equations, but the person asking for help struggles with the math. Another person suggests using trigonometric identities to simplify the equations. The original person apologizes for not understanding the suggestion due to being on medication for a broken arm.
kirbykirbykirby
Pretty easy relative velocity question but I suck at Physics. I wanted to check my diagram and if it is not right than ask for help on a mathematical approach because mine is not working.
The question is: An airplane, who air speed is 600 km/h, is supposed to fly in a straight path 35.0 degrees north of east. But a steady 100 km/h wind is blowing from the north. In what direction should the plane head?
http://www.oddworldz.com/octachoron/qyestuib53.jpg
It's not artistic but I hope it's understandable. The angle between the black arrow from origin and either vertical or horizontal is what I need to find. By the way: not to scale.
Answer at back of book is: 42.9 degrees N of E
This is the beginning of my approach which probably doesn't follow all math rules and is therefore ridiculous.
600cosA = xcos35
600sinA - 100 = xsin35
Thanks for any help or hints or links on how to do math or anything.
If no one answers before 7:00AM PST tomorrow don't bother because I'll check the solutions book at school.
You want to use vector addition, you have th emagnitude of the plane's velocity as 600km/h , and the total desired velocity vector (direction), you'll want to find a combination of three vectors (plane, total, and air) such that the sum of the plane vector and air vector = the total vector.
OK. I have no idea what that meant. It seems like a convuluted re-statement of the question to be honest.
http://img470.imageshack.us/img470/1309/redone6wk.th.jpg
I tried to show how I broke them down into components here.
In Y:
-100 for the wind
600sinA for breakdown of plane velocity in Y
In X
600cosA for plane v
that's where I got my approach from.
Sooo... can anybody please help me out.
Can't help you cause we can't see your pictures..
Try setting up a system of equations for the X and Y components, you should have 2 equations and 2 unknowns.
Refering to my first entry:
600cosA = xcos35
If you are saying that it is correct so far and those equations are right than I simply don't have the mathematical skills to solve it, of course I am assuming you are an authority figure on the area of Physics because you have 2000 posts.
So if all that's right just confirm and I'll fool around with them for a couple more hours.
I'm no expert, this could be wrong. I'm on medication so I'm not thinking straight, but no one else is helping you..
[itex] \cos(x) = \sin(90 - x) [/itex]. I would try applying this to the right hand side of the first equation, might make things easier for you.
I am aware of that and I wasn't complaining. Maybe I should though because now I learned you're high. I'm only kidding, sorry you have a disease or mental problem or something.
Thanks for the help, this is going to take me awhile. It took me 15 minutes to figure out what that last thing you said meant.
I broke my arm and am on prescription pain killers, I'm mentally intact thanks :)
1. What is relative velocity?
Relative velocity is the velocity of an object in relation to another object. It takes into account the motion of both objects and allows for the calculation of their combined velocities.
2. How is relative velocity calculated?
Relative velocity is calculated by finding the vector sum of the individual velocities of the objects. This is typically done using trigonometric functions and vector algebra.
3. How does wind affect relative velocity?
Wind affects relative velocity by adding its own velocity to the velocity of the object. This can result in a change in the direction and speed of the object's overall velocity.
4. How does the angle of the airplane's flight path affect relative velocity?
The angle of the airplane's flight path affects relative velocity by changing the direction of the airplane's velocity in relation to the wind. This can result in a different overall velocity for the airplane.
5. Why is it important to consider relative velocity in air travel?
Considering relative velocity in air travel is important because it allows for the prediction and control of an airplane's flight path. It also helps pilots to adjust their speed and direction in response to wind and other factors, ensuring a safe and efficient flight.
12K
