Relativistic Momentum and Energy
3 replies · 2K views
Peter G.
Hello guys,
The question is: What is the momentum, in conventional SI units, of a proton of momentum 685 MeVc-1?
So, I tried two methods which yielded slightly different answers, both proximate to the actual answer (3.66 x 10-19)What I first tried to do was to rearrange: ρ=γm0v
To find the particles velocity and then multiply it by the proton's rest mass in kg. I got 2.995 x 10-19 kgms-1
The second method, which gave me the result 3.45 x 10-19 kgms-1 was the following:
From: E2 = (m0)2c4 + p2c2 I got a value for total energy. I then subtracted the rest energy from that and I got a value for KE.
I equalled that to p2/2m and solved for p (using m in kg and the energy converted from MeV to J)
Are my answers wrong? The book says 3.66 x 10-19 and I simply can't get that!
Thanks in advance!
the book answer is correct.
a question for you : What does MeVc-1 mean?
can you do a dimension analysis on MeVc-1
Oh, got it! Thanks! I got the number!
Oh, and, if you don't mind, could you (or anyone else) help me with the following problem please?
A proton initially at rest finds itself in a region of uniform electric field of magnitude 5.0 x 106 Vm-1. The electric field accelerates the proton for a distance of 1 km.
Find the kinetic energy of the proton.
So, what I did was the following:
KE = q * E * s
I then converted the result from J to MeV. I, however, get 5000 MeV and the book gets 500 MeV. Is my line of thought incorrect?
Thanks once again!
