Resistance in a wire, sanity check about units.
The discussion revolves around calculating the resistance of a wire using the formula R = p*L/A, where resistivity (p), length (L), and cross-sectional area (A) are key factors. The user initially converted units incorrectly, leading to a significant miscalculation of resistance. After clarifying the conversion of resistivity from ohm-cm to ohm-m, the correct resistivity value is established as 4.0 x 10^-9 ohm-m. With the proper values, the resistance calculation yields the accepted answer of 0.0113177 ohms. This highlights the importance of accurate unit conversion in physics problems.
Cade
A x cm long wire has a diameter of y mm and a resistivity of 4.0x10-7 ohm-cm. Calculate its resistance.
R = p*L/A
First, I convert the given information into SI units:
Length = x*10^-2 m
Diameter = y*10^-3 m
Resistivity = 4*10^-5 ohm/m
Next, cross-sectional area of a wire/cylinder is pi*r^2 = pi*(d/2)^2 = (1/4)pi*d^2
R = p*L/A = p*L/((1/4)pi*d^2) = (4 L p)/(d^2 pi)
If x = 20 cm and y = 0.3mm,
R = (4*20*10^-2 *4*10^-5)/((0.3*10^-3)^2*Pi) = 113.177 ohms
Is this correct? My TA told me that I converted the units wrongly, and that the correct answer is 0.0113177 ohms.
How did you convert 4.0*10-7 ohm-cm to units of ohm-m ?
1 cm = 1*10-2m .
4.0*10-7 ohm-cm * 10^-2 m/cm = 4.0*10^-9 ohm-m
Oh, that's the mistake, I did it in the opposite direction.
And now you should get the accepted answer.
