Is my solenoid's resistance too low?
The calculated resistance of the solenoid is 0.175 ohms, which raises concerns about whether this value is too low. The solenoid consists of 240 turns of 1.6mm wire, totaling 21.96 meters in length. While low resistance is noted, the key factor is whether the wire can handle the expected current of 10A without overheating. It's emphasized that the type of power supply needed for such a solenoid should provide low voltage with high current capacity. Ultimately, the focus should be on ensuring the wire's specifications meet the current requirements for safe operation.
thomsonm
I've just calculated the resistance of a solenoid I'm making, but it seems far too low.
240 turns of 1.6mm wire, 30 turns per row, 8 rows deep.
total length of wire (L) = 21.96m
area of wire (A) = pi * (0.0008)^2 m^2
resistivity of copper (rho) = 1.6*10^-8 ohms m^-1
R = (rho * L) / A
R = 0.175
Is the resistance of my solenoid really only 0.175ohms?
There will initially be some inductive reactance as well...
How 'low' the resistance of something is really doesn't mean anything. Someone once asked me how low of a resistance you could get 'before it shorts out'. A meaningless question. If the wire size you have chosen will handle the current you end up putting through there without burning up then you are fine. So what kind of current do you expect to put through the solenoid?
I'm need 10A to get the right magnetic field.
Ideally, an inductor would have zero resistance.
To supply a solenoid satisfactorily you tend to need an unusual sort of power supply - low voltage and loads of current available.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
