Resultant linear acceleration at the rim of a disk
The problem involves a uniform disk rotating in a horizontal plane, with a focus on determining the resultant linear acceleration at the rim of the disk after it has turned through a specified angle. The context includes angular motion and the relationship between angular and linear quantities.
  • Exploratory, Assumption checking
  • Participants discuss the calculations related to angular and tangential acceleration, questioning the interpretation of the problem and the definition of linear acceleration.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the distinction between tangential and linear acceleration, and there is recognition of potential misconceptions in the initial approach.
There is a noted confusion regarding the specific requirements of the exercise, particularly whether the linear acceleration refers to a point on the rim of the disk or a particle that has detached from it. Participants are also considering the implications of constant angular acceleration and its effects on linear acceleration.
fuddyduddy
A uniform disk with radius 0.390m and mass 27.0kg rotates in a horizontal plane on a frictionless vertical axle that passes through the center of the disk. The angle through which the disk has turned varies with time according to θ(t)=( 1.50rad/s)t+( 9.00rad/s2)t2 .
What is the resultant linear acceleration of a point on the rim of the disk at the instant when the disk has turned through 0.100rev ?
tangential acceleration = r * α
The velocity equation should be the derivative of the position equation, so
θ(t) = 1.5t + 9t2 → ω(t) = 1.5 + 18t
Derivative of velocity equation should be acceleration so
ω(t) = 1.5 + 18t → α(t) = 18 rad/s2
Now at = rα = (0.39m)(18 rad/s2) = 7.02 m/s2
Where did I go wrong?
What is the exercise asking for, precisely ?
Oh! My fault! It's asking:
Can't find a flaw in your work. Why do you think it's wrong ?
Because mastering physics says it is incorrect :/
Well, then it definitely must be wrong... So either we both make the same calculation error or we both have a wrong perception of what's going on.
Let's bet on the latter: we both thought the tangential acceleration would be the answer. In other words: we calculated the acceleration of a particle that thus far has been attached to the disk and isn't any more. That can well have been our misconception:
perhaps the writer of the exercise wants the linear acceleration of a particle that stays in the same place on the rim of the disk ...
I can't help but feel a litlle bit tricked :(
What would be the difference? Isn't the angular acceleration constant and the radius constant, thus making the linear acceleration constant for any point on the disk at that radius?
Tangential acceleration is constant indeed. But apparently, linear acceleration ##\ne## tangential acceleration.
The particle experiences a force to undergo this angular acceleration and also a force to stay in a circular trajectory on the rim of the disc.
What I suspect the exercise means is: the linear acceleration squared is radial squared plus tangential squared
And I must admit that linear acceleration is defined as ##\ddot { \vec x }##
Ah I see what you mean now. We both misinterpreted the problem, thanks for working through it with me!
