Calculating Magnitude of Resultant Vector for X Added to Y = 12i -16j
To find the magnitude of vector X added to vector Y = 12i - 16j, the resultant vector must lie along the positive x-axis and equal the magnitude of X. This implies that the y-component of the resultant must be zero, leading to the equation -16 + Y_y = 0, where Y_y is the y-component of vector Y. Solving for the magnitude of X involves using the Pythagorean theorem, considering the components of Y. The calculations suggest that the correct magnitude of X is approximately 20.7. The problem emphasizes understanding vector addition and the conditions for resultant vectors.
tommy2st
A vector X is added to vector Y = 12i -16j. The resultant vector lies along the positive x-axis and has the same magnitude as X. What is the magnitude of X?
a. 20.7
b. 16.7
c. 11.3
d. 4.7
What have you done so far to work this out? What are you stuck on?
