mrmonkah
- 24
A house is heated by means of a carnot engine operating in reverse (Heat Pump). The outside Temperature (Tc) is 270k, and the required inside temperature (Th) is 300k. If heating the house to this temperature normally requires 10kW of electrical heating, how much power is consumed by the carnot heat pump to maintain the same temperature?
n = \frac{W}{Q1} = 1 - \frac{Tc}{Th} = 0.1
I'm really having problems labelling each of the 'heat exchanges. I have Tc as the cold reservoir and Th as the hot reservoir. Should my heat from Tc be Q1 and then work is done, followed by Q2 into the hot reservoir? Then use the relevant equations to get the power consumption of the engine?
