What is the magnitude of the aftershock
  • Thread starter Thread starter gatita0225
    Magnitude Scale
An earthquake with a magnitude of 5.4 is 39 times more intense than its aftershock occurring 5 hours later. To find the aftershock's magnitude, the relevant equation is m = log_10(i/i_0), where i is the intensity of the aftershock. The intensity ratio allows for the cancellation of i_0, simplifying the calculation. By using the product rule for logarithms, the problem can be approached more easily. Ultimately, the aftershock's magnitude can be determined without needing to know the specific value of i_0.
gatita0225
An earthquake with a magnitude of 5.4 is 39 times as intense as an aftershock that occurs 5 hours later. What is the magnitude of the aftershock.
m=log_10(i/i_0)
I know that I what to find the magnitude
m=log_10(39/i_0)
I am stuck because I do not know what # do I replace "/i_0' with..please help!?
You don't need it, the i_0 is irrelevant.
Look at it this way: m1 = 5.4 = log(39x/i_0) = log(39x) - log(i_0).
and m = log(x/i_0) = log(x) - log(i_0).
You can cancel out the i_0, since it won't help you.
*edit* Even more simply, let x= i/i_0, then there is even less to worry about. Just remember the product rule for logarithms.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
