Rocket travelling up and down - kinematics
  • Thread starter Thread starter hotmail590
    Kinematics Rocket
A model rocket accelerates upward at 40.0 m/s² for 2.59 seconds before entering free fall. The maximum height reached by the rocket is calculated to be 94.375 meters. After the engine stops, the rocket falls back to the ground, where its speed just before impact is determined to be -43.0083 m/s. The calculations involve using kinematic equations that account for both upward acceleration and gravitational effects. The results have been verified by multiple participants in the discussion.
hotmail590
A model rocket has a constant upward acceleration of 40.0m/(s^2) while its engine is running. The rocket is fired vertically, and the engine runs for 2.59s before the fuel is used up. After the engine stops, the rocket is in free fall. The motion of the rocket is purely up and down.
What is the maximum height that the rocket reaches?
What will b e the speed of the rocket just before it heats the ground?
Yes I have looked through the forums for similar posts similar to my question and I have found one https://www.physicsforums.com/showthread.php?t=44459&highlight=rocket
However that one does include a given initial velocity and my problem does not. I do not know where to start.
Thank you very much for your help.
You can use the same equations mentioned in that thread, except you don't need an initial velocity term.
The base kinematics equation is s = ut + \frac{1}{2}at^2. In your case, you can use h = \frac{1}{2}(a-g)t^2
where h is the height at time t, (a - g) is the net upward acceleration (taking the opposing effect of gravity into account) and t is the time.
For the second part, just use v^2 = 2gh. That can be gotten either from conservation of energy or the base kinematics equation v^2 = u^2 + 2as
The problem is really simple.Compute the acceleration upwards.Then use the fact that gravtity does not vary significantly and conclude that the acceleration u computed is constant.
Then find the height and the final velocity in free fall.
Daniel.
Thank you very much for you help everyone
I have worked it out and got the final answers
Greatest height = 94.375 meters
and
Velocity at ground = -43.0083 m/s
Can someone please verify?
[] Greatest Height
a = 40m/s^2 - 9.8m/s^2
t = 2.5 seconds
Velocity Final and Initial = 0
Xo = 0
X =?
Using the position function
x=1/2(a)(t^2)+Vo(t) +Xo
= (1/2)(40 - 9.8)(2.5^2)
[] Velocity at Ground
a = - 9.8m/s^2
t = ?
Velocity Final = ?
Velocity Initial = 0
Xo = 94.375
X = 0
0=(1/2)(-9.8)(t) + 94.375
t=4.3886 seconds
Plug time into Velocity function (deriv of postion)
Velocity = -9.8(4.3886)
= -43.0083 meters/second
