Calculating Rotational Motion: Solving for Time in Uniform Door Rotation
  • Thread starter Thread starter pinky2468
    Axis Rotation
The discussion revolves around calculating the time it takes for two identical doors to rotate through the same angle under the influence of a force. Door A rotates about its left edge, while Door B rotates about its center, with the same force applied at their right edges. The user struggles with incorporating time into their calculations, having derived the torque equations but unsure how to proceed. The key advice is to treat the doors as separate cases, using the angle of rotation from Door A to find the angular acceleration for both doors. Ultimately, understanding the relationship between torque and angular motion will help solve for the time taken by Door B.
pinky2468
I am having a very hard time with this problem! Even my teacher had trouble with it(of course we are still expected to have it done on our homework!)
2 doors are uniform and identical. Door A rotates about an axis to its left edge and door B rotates about an axis through the center. The same force F is applied perpendicular to each door at its right edge and the force remains perpendicular to as the door turns. Starting from rest, door A rotates through a certain angle in 3.00s. How long does it take door B to rotate through the same angle.
So I got as far as 1/3ML^2(alpha)=1/12M(L/2)^2(alpha) and then I get stuck on how o make time fit in. I have been looking at all the equations for rotational motion, but I don't know which one?
Use \tau = I \alpha to find the \alpha for each case. Then apply the kinematic equation that gives \theta as a function of time.
This is what I am coming up with:
1/3ML^2(2\theta/t^2)= 1/12ML/2^2(2\theta/t^2)
ML^2 cancel out and so does the 2\theta
and I am left with (1/3)(1/t^2)=(1/12)(1/4)(1/t^2)
Is that right? Where do I go from there?
The torque is different in each case.
But the same force is applied to each door in the same spot?? If the torque is different then I am not sure what to do b/c the only known value is time.
A: torque is FL
B: torque is FL/2
That is what I had, but can't I set them equal to each other?
No, since they are not equal! You can easily relate them though.
You should use the information given to find out the angle for door A. Treat door A and B as separate cases, door A is there just to tell you the angle. Then you find out the \alpha from the \tau and I that you already have. If you can find out the angle of door A, then you shouldn't have problem working out time for door B because it's sort of working backward with the method you used for A.
