What is the tension in the string immediately above the block?
The discussion focuses on calculating the tension in a string connected to a uniform cylinder and a block. The cylinder rolls without slipping, and the block descends with a known acceleration. The tension above the block was initially calculated to be 83.4 N, but the user struggled with determining the tension connected to the cylinder's handle. Key equations involving Newton's second law for both rotation and translation were discussed, emphasizing the roles of friction and tension in the system. The final clarification involved expressing the net force and torque in terms of tension and friction to arrive at the correct tension value.
hayowazzup
[SOLVED] Rotation and Translation
A uniform cylinder of mass M=21.3 kg and radius R = 18.1 cm rests on a horizontal table-top. The cylinder can rotate about a frictionless axle that has a light handle connected to it. A light string passes over a disk shaped pulley of mass mp=5.2 kg and radius r = 8.51 cm and connects a block of mass m = 11.3 kg to the cylinder handle as shown in the diagram. Upon release, the cylinder rolls without slipping on the table, the string moves without slipping over the pulley surface and the block descends with acceleration a = 2.42 m/s²
(a)What is the tension in the string immediately above the block?
(b)Determine the tension in the string directly connected to the light handle?
for the first one i got 83.4, but i don't know how to work out the second question
I=rw?
T= (9.8-2.42)11.3
Start by analzying the forces acting on the cylinder. The big difference here is that you have to worry about rotation as well as translation, so you'll be applying Newton's 2nd law twice. Hint: There are two horizontal forces acting on the cylinder. What are they?
oh, i guess one of them should be the friction of the cylinder, but i have no idea how to get it from its radius and mass
Yes, friction and string tension are the two horizontal forces acting on the cylinder. You'll solve for the friction (if you need to find it, which you don't). For now, just label it "F" and write Newton's 2nd law for rotation and translation.
Be sure to draw yourself a simple free body diagram of the cylinder.
...N
F<-- ( ) T-->
...(mg)
Torq= I(a/r)
F=ma
hmm...I still don't get this
hayowazzup said:
Torq= Iw
That should be:
\tau = I \alpha
F=ma
OK. Now write these two equations as they apply to this problem, in terms of friction' and tension.
How does the angular acceleration relate to the translational acceleration?
a= radius * angular acceleration
2.42m/s^2 = 0.181m* ang acceleration
angl acc = 13.37rads^2
I = (1/2)*21.3kg*0.181^2
I= 0.3489
torque = I * angular acceleration
torque = 0.3489 * 13.37 = 4.66
Torque = I * angular acc
Torque = F*r
F=ma
Force 1= ma = 21.3k*2.42= 51.546
Force 2= Torque/ r = ((1/2)*M*r^2)*(a/r)/ r = 4.66/0.181 = 25.74
Ftotal= Force 1 + force 2= 51.546+25.74
can you tell me where it goes wrong?
by comparing it to the one in the book, they are close if i round it off to 2s.f.
What you call "Force 1" is really the net force. How does this relate to the friction' and tension?
Rework this a bit. There are two forces acting on the cylinder: Tension and friction. Label them T and F. Express all your equations in terms of those forces.
What's the net force? What torque does each force produce?
so the Net force= Tension - friction
Tension = Netforce + friction ?
Net force= Tension - friction = mass*acceleration= 21.3*2.42= 51.546
Friction= Torque/ r = ((1/2)*M*r^2)*(a/r)/ r = 4.66/0.181 = 25.74
Tension= Net force + Friction= 51.546+25.74
That's much clearer.
OK.
Good. Realize that F = 1/2 M r^2*(a/r^2) = 1/2 Ma = 1/2 (51.546)
Looks good to me.
