Understanding Rotation Curves: A Study of Galactic Density and Derivatives
  • Thread starter Thread starter Dan_
    Curve Rotation
The discussion focuses on calculating rotation curves using a double integral approach based on Casertano's 1982 formula. The key equation involves the density function p(r,z) and its derivative, which are essential for understanding galactic density. A challenge arises in limiting the double integral for accurate calculations. The user seeks guidance on how to properly constrain the integral limits in their C# implementation. The conversation emphasizes the importance of precise mathematical modeling in astrophysics.
Dan_
Hello, I make the calculation of the curve rotation. Casertano(1982г.)
V^{2}=-8GR \int_{0}^{\infty}{r} \int_{0}^{\infty}{ [\frac {\partial p(r,z)} {\partial r}] \frac {K(p)-E(p)} {\sqrt{R r p}}}dzdr
p = x - \sqrt{x^{2}-1} x=(R^{2}+u^{2}+z^{2})/(2Rr)
Density
p(r,z) = p_{0} \exp(-r/h) [ch(z/z_{0})]^{-2}
Derivative
\frac {\partial p(u,z)} {\partial u} = \frac {-p_{0} \exp(-r/h) [ch(z/z_{0})]^{-2}} {h}
Original article http://articles.adsabs.harvard.edu//full/1983MNRAS.203..735C/0000737.000.html
The problem is this. Double integral should be limited. I do not know how.
Astronomy news on Phys.org
Calculation in C# http://pastebin.com/Dx4xkzYy
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
