Rotational Kinetic Energy of bicycle wheels
The discussion focuses on calculating the fraction of the total kinetic energy of a bicycle that is attributed to the rotational kinetic energy of its wheels. The bicycle has wheels with a radius of 0.33 m and a rotational inertia of 0.082 kg*m². The total mass of the bicycle and rider is 74 kg. The equations for rotational kinetic energy (KE) and linear KE are presented, with an emphasis on how to combine them to find the total KE. The user expresses confusion about the calculations, specifically regarding the number of wheels and the final result, indicating a need for clarification on the problem.
rugbygirl
A bicycle has wheels of radius 0.33 m. Each wheel has a rotational inertia of 0.082 kg* m2 about its axle. The total mass of the bicycle including the wheels and the rider is 74 kg. When coasting at constant speed, what fraction of the total kinetic energy of the bicycle (including rider) is the rotational kinetic energy of the wheels?
I thought this: Rotational KE = (1/2)Iw^2
=(1/2)(second bold number)w^2
Linear KE= (1/2)mv^2
= (1/2)(third bold number)(radius*w)^2 (i.e. plug in r*w for v)
Total KE is equal to Rotational KE + Linear KE
add the two eqns
(1/2)Iw^2/ (some # * w^2)
i think you are correct
eventually one takes away the w^2 in both numerator and denominator, then gets a result independent of w
i keep getting .041/4.07 and that is not right
How many wheels does a bicycle have?
Please post in the HW forums.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
