Rotational Motion maximum speed
3 replies · 3K views · last reply
physgrl
3. A 1500 kg car is moving on an un-banked curve with a radius of 98 m. The coefficients of static and kinetic friction are 0.73 and 0.50 respectively. The maximum speed the car can move without skidding is:
*a. 27 m/s
b. 22.4m/s
c. 21 m/s
d. 30 m/s
e. none of the above
Fn*μ=mv2/r
I used that formula with the coefficient of kinetic friction (because the object is in motion when it has velocity) and I got 21.9...the answer key says its 27.
Have you tried using static friction? Until the vehicle begins drifting, you only have static friction. At every instant in time, the rubber that is in contact with the road surface is not moving relative to the road surface. It's called the instantaneous center.
If the car is not sliding sideways, you would use the coefficient of static friction. The static friction force is perpendicular to the direction of motion at all times.
AM
Ohhh got it i was thinking about friction in the other direction. Thanks
