Solve Rotational Motion: Show Tension = 1/3 Disk Weight
The discussion focuses on deriving the relationship between tension in a string wrapped around a uniform disk and the weight of the disk. The user attempts to show that tension equals one-third of the disk's weight using torque and moment of inertia equations. They correctly set up the torque equation but mistakenly conclude that tension equals half the weight instead of one-third. The community is asked to identify the error in their calculations. Clarification on the correct approach to solving the problem is sought.
thenewbosco
I have a diagram for this at http://snipurl.com/diagr
There is a uniform disk with radius R, mass M, it has a string wrapped around it and is attached to a fixed rod.
Part 1: Show the tension in the string is 1/3 the weight of the disk
what i have done for this is
Torque=Fd
and setting the force equal to Tension
Torque=TR
then \sum Torque=I\frac{a}{R} and i used I=\frac{1}{2}MR^2for the moment of inertia
Then TR=\frac{1}{2}MRa
T=\frac{1}{2}Ma
and then acceleration is just g, so i get the tension equals 1/2 the weight. where have i gone wrong?
Access is forbidden to your link.
help??
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
