Solve Rotational Questions for Translational Speeds & Angular Speed
  • Thread starter Thread starter clphipps
    Rotational
The discussion focuses on solving a physics problem involving two objects connected by a string over a frictionless pulley with moment of inertia. Using the conservation of energy principle, the equation 1/2m1v1^2 + 1/2m2v2^2 + 1/2Iω^2 = 9mg is established to relate the translational speeds of the objects and the angular speed of the pulley. By rearranging this equation, expressions for v1 and v2 are derived, allowing for the calculation of the angular speed ω. The final results indicate that the translational speeds of the objects as they pass each other are v1 and v2, while the angular speed of the pulley is ω. This approach effectively integrates concepts of rotational dynamics and energy conservation.
clphipps
Consider two objects with m1>m2 connected by a light string that passes over a pulley having a moment of inertia of I about the axis of rotation. The string does not slip on the pulley or stretch. The pulley turns without friction. The two object are released from rest by a vertical distance of 9h.
Use the principle of conservation of energy to find the translational speeds of the objects as they pass each other?
Find the angular speed of the pulley at this time?
Conservation of energy: 1/2m1v1^2 + 1/2m2v2^2 + 1/2Iω^2 = mgh Using this equation and substituting the values given, we have 1/2m1v1^2 + 1/2m2v2^2 + 1/2Iω^2 = 9mg We can solve for v1 and v2 by rearranging the equationv1^2 = 2(9mg - 1/2m2v2^2 - 1/2Iω^2)/m1 v2^2 = 2(9mg - 1/2m1v1^2 - 1/2Iω^2)/m2 We can then solve for ω using either equationω^2 = 2(9mg - 1/2m1v1^2 - 1/2m2v2^2)/I Therefore, the translational speeds of the objects as they pass each other is v1 and v2, and the angular speed of the pulley is ω.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
