Why Does the Scale Read Higher at the Top of a Rollercoaster Loop?
The discussion centers on understanding why a bathroom scale reads higher at the top of a rollercoaster loop. Initially, the scale shows a weight of 65 kg, but at the top of the loop, it reads 77 kg due to the combined effects of gravitational force and centripetal acceleration. The normal force (Fn) is equated to the scale reading, and the centripetal force is calculated using the formula Fc = Fn + Fg. The calculations lead to a centripetal acceleration of 21.4 m/s², which is then used to determine the speed at the top of the loop, approximately 17.9 m/s. The discussion highlights the importance of understanding forces and measurements in non-level conditions.
doug1
You take a bathroom scale onto a stand-up rollercoaster (the riders are always in a standing position). Before the ride
starts, you stand on the scale and note that it reads 65 kg. The ride starts and at the top of the first loop you are upsidedown and your scale reads 77 kg. You estimate that the loop has a radius of 15 m. How fast were you going at the top
of the loop?
Fn = reading of scale
Fg = mg
ac = v^2/r
I drew a FBD where the normal force and the force of gravity both point downwards towards the centre of the circle. The centripetal force equals the sum of the normal force and the force of gravity:
Fc = Fn + Fg
The problem is that I don't know what Fn is. Is it (77kg)(9.8N/kg)? If this is the case, I would then do:
Fc = (77kg)(9.8N/kg) + (9.8)(65)
I would then divide this value by 65 to get the centripetal acceleration (21.4 m/s^2).
I would then plug 21.4 m/s^2 into the equation ac = v^2/r and solve for v (about 17.9 m/s)
of the loop?
Fg = mg
ac = v^2/r
Fc = Fn + Fg
Yes, it is. :approve:
Bathroom scales are good at measuring the normal force on a level surface (regarding the normal force acting on objects standing on the scale). That's pretty much all they're designed to do. :smile:
It's a bit tricky here only because the particular bathroom scale you are working with gives its measurement in units of kilograms -- a measure of mass, not force. The bathroom scale assumes (correctly or not) that the total acceleration has magnitude g (i.e. 9.8 m/s2). So you are correct when you equate Fn = (77 [kg])(9.8 [N/kg]).
That looks right to me.* :smile:
*(There are some assumptions being made such that the radius of the loop is in regard to your own center of gravity as you move around the loop [which is not quite the radius of the track], and g = 9.8 N/kg. And there's also an assumption that the top plate of the bathroom scale has negligible mass. But regardless of all that, you're on the right track. :approve:)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
