Scrap Steel Refining: Separating Metals for New Steel
  • Thread starter Thread starter LAP3141
    Steel
Recycling scrap steel involves refining it to produce new steel alloys, such as 4140, which require precise compositions of various metals like manganese, vanadium, and chromium. The challenge lies in separating these alloying elements from the scrap melt, as different types of scrap steel contain varying proportions of these metals. To create a specific alloy, the scrap must first be purified to remove unwanted alloying agents. This purification process typically involves manual sorting of the scrap based on chemical analysis, as well as techniques like electrolysis to eliminate impurities. However, the discussion raises a critical question about the feasibility of chemically or physically separating individual alloy components from a mixed steel alloy, such as 4140, suggesting that such separation may not be possible. The conversation highlights the complexities involved in recycling steel and the importance of precise material composition in steel production.
LAP3141
A lot of scrap steel is recycled to make new steel. But how is this scrap steel refined?
Recycled scrap must be a mixture of various types of steel with each type containing different amounts of manganese, vanadium, chromium, etc. How are these other metals separated from the scrap melt so that new steels, such as 4140, which have a strict specification, be produced?
The carbon additives can be oxidized out, but I'm not sure how the metallic additives can be separated.
Chemistry news on Phys.org
Bystander said:
Perhaps you misunderstand the issue.
Steel is an alloy and the different types of steel contain different proportions of added metals such as manganese, molybdenum, vanadium, chromium, silicon, etc. Scrap steel must contain mixtures of different steel alloys and when this scrap steel is melted it will likely not be a match to any commercial alloy.
In order to make a specific steel alloy, such as 4140, a precise amount of added metals must be added to the melt. Thus, any scrap steel that is used to make 4140, or any other steel alloy, must first be purified by separating the alloying agents (molybdenum, vanadium, etc.).
How is this separation accomplished? How is the molybdenum, vanadium, chromium, silicon, etc. separated from the scrap steel melt to leave just pure iron?
jim mcnamara said:
Separation or sorting by type of steel = manual. Sometimes impurities (not alloying metals) are removed by electrolysis during the melt.
See: https://www.thermofisher.com/blog/metals/why-scrap-metal-recyclers-need-to-know-their-steels/
I did not realize that scrap recyclers performed elemental analysis on their product. I thought that they only separated ferrous from non-ferrous scrap and sent the all the ferrous material together to the mill as one big collection.
So manual sorting of the ferrous material based on a chemical analysis is the method used.
But one question still remains. Is there a chemical or physical method to separate the components of a steel alloy? I would tend to think that it's not possible to do so. That is, if we have 4140 steel, can the molybdemum, vanadium etc, be separated from the iron either chemicaly or physically?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
