Second order reaction, conversion in a CSTR
7 replies · 4K views
MichelV
We have a second order reaction: A + B → C + D with -rA = k[A][ B]
[A]0 = [ B]0 = 300 mol / m3; τ = 11 minutes.
k = 4.0 × 10-4 m3 / (mol × minutes)
What is the conversion in a CSTR?
I think:
τ = ([A]0 - [A]1) / -rA,1
τ = (XA × [A]0) / -rA,1
But since I don't know the conversion, I don't know the concentrations at the CSTR output. And because I don't have a volume or flow rate I don't know how to proceed.
1 / [A] = 1 / [A]0 + kt
1 / [A] = 1 / 300 + 4.0×10-4×11
1 / [A] = 0.0077333
[A] = [ B] = 129.3 mol
-rA = 4.0 × 10-4 × 129.32
-rA = 6.688
Rearranging the second formula in the relevant equations for X gives:
XA = (-rA,1 × τ) / [A]0
XA = (6.688 × 11) / 300
XA = 0.25
But the answer should be 0.43 and I don't know how to get there.
Thanks in advance.
Hello Michel, :welcome:
You have to sort out your equations a little better. These really won't do; the dimensions don't fit.
Set up a differential equation for [A] (or ) and solve it. The 0.43 is correct.
[edit]sorry, bad response. The 129.3 is correct. So: what is the conversion ?
Is the solution of the differential equation I mentioned. (It's good to check how this was deducted!) In your exercise, t = ##\tau## and so you can calculate [A] = 0.007733 mol / m3 after 11 min. And the conversion (it is not 0.43).
Thank you for the help. I've looked at the differential equation and it makes much more sense now.
If we know that [A] = 129,3 mol / m3 at the output of the CSTR and we know that X = 1 - ([A] / [A]0) this means that:
X = 1 - (129.3 / 300) = 0.57
So the conversion for this reaction in a CSTR is 57%.
I believe this should be the correct answer.
##\tau## is supposed to be the mean residence time in the CSTR. If F is the feed rate, then the steady state mass balance on the reactor is $$F(A_{in}-A_{out})=-rV$$ where V is the volume of liquid in the reactor and $$r=kA_{out} B_{out}$$So, $$(A_{in}-A_{out})=-k\tau A_{out} B_{out}$$where ##\tau=V/F##. If X represents the number of moles of A (per unit volume) converted, then $$A_{out}=A_{in}-X$$and $$B_{out}=B_{in}-X$$So, combining these equations, we get: $$k\tau(A_{in}-X)(B_{in}-X)=X$$
Solve this quadratic equation for X.
This gives a 43% conversion.
Thank you for the clear explanation! I got it now.
