Seemingly easy quantum question
  • Thread starter Thread starter bemigh
    Quantum
The discussion centers on calculating the wavelength of a particle confined in a one-dimensional box using its mass, box length, and quantum number. The correct energy formula for a particle in a box is E = (n^2 * h^2) / (8mL^2), which should be used to find the energy before applying E = hf to determine the wavelength. A participant suggests that using the relativistic energy equation is unnecessary for this scenario since the particle's mass is accounted for in the box model. The importance of double-checking calculations for accuracy is emphasized. Overall, the process outlined is valid, but attention to detail in calculations is crucial.
bemigh
Hey, i don't understand why i can't seem to find this answer??
Im given the length of the box, the mass, the value of n, i can solve for E of the particle, then using E=hf, solve for eventually the wavelength.
Is their something wrong with my process??
A particle of mass 2.13×10-28 kg is confined to a one-dimensional box of width 1.18×10-10 m. For n = 1 , what is the particle's wavelength?
Cheers
I would use the relation E^2 = p^2c^2 + m_0 c^2 (relativistic energy) to find E and then use the De broglie relation to find lamda. E = hf wouldn't work since we are dealing with a particle with mass.
for asking for clarification on this question. It seems like you have the right approach, and there may be a small error in your calculation. Remember that the energy of a particle in a one-dimensional box is given by E = (n^2 * h^2) / (8mL^2), where n is the quantum number, h is Planck's constant, m is the mass of the particle, and L is the length of the box. Once you have calculated the energy, you can use E = hf to solve for the wavelength. Make sure to double check your calculations to ensure accuracy. Good luck!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
