Selecting Vgs and Vds for MOSFET Amplifier
  • Thread starter Thread starter d0wn7h1ft
    Amplifier Mosfet
Selecting Vgs and Vds for a MOSFET amplifier requires careful consideration of device characteristics and circuit requirements. While datasheets can provide some guidance, they may not always yield accurate biasing points. Creating a Vgs vs Vds curve is one method to visualize the relationship between these parameters, but it may involve trial and error. Simulation software like Multisim can also help in determining optimal biasing points more efficiently. Ultimately, a combination of methods and consultation with experienced engineers is recommended for successful design.
d0wn7h1ft
Hello All,
I just finished a college course on electronic circuits (opamps, mosfets, bjts, etc) and I'm trying to put some of that knowledge towards designing a basic MOSFET amplifier circuit. Right now I'm at the stage of selecting DC biasing points and I'm having a bit of difficulty selecting these values.
http://www.datasheetcatalog.org/datasheet/irf/jantx2n6770.pdf
Above is the datasheet for the part I am using in my multisim simulations. Is there any way of determining what my Vgs DC biasing point for saturation region should be just based on the datasheet. I ask this because I don't know whether or not it is common practice in design to always create a Vgs vs Vds curve to find the appropriate Vgs DC bias point. From what my professor told me we should be able to look at a datasheet and find out what we need to set our Vgs DC to but I don't know how to do that based on the information given in the datasheet.
Any help with this would be greatly appreciated. I'm just having some difficulty bringing the classroom knowledge into the real world where all of the specific device parameters aren't explicitly listed.
In real world design we don't use Vgs vs Vds curve to find the appropriate Vgs DC bias point. For all single stage amplifiers we usually select Vds = 0.5Vdd.
https://www.physicsforums.com/showthread.php?p=4058469#post4058469
And we find Vgs in real world measurement. And sometimes we use this equation as first approximation method.
I_D = K*(V_{GS} - V_{GS(th)})^2
then form this equation
\Large K = \frac{I_D}{(V_{GS} - V_{GS(th)})^2}
And so for example from IRF510 datasheet
http://inst.eecs.berkeley.edu/~ee40/su10/labs/Booster/IRF510.pdf
That the average value of Vgs(th) is equal to Vgs(th) = (2 + 4) / 2 = 3V
And from Figure 5 that, for Vgs = 5V we have Id = 1A
K = Id/(Vgs - Vgs(th))² = 0.25 = 1A/(5V - 3V)^2 = 0.25.
So we have all the data that we need for now.
That makes a lot of sense, thank you. I do have one more question about this though. I was reading over my textbook and they mentioned using the Vds vs Id graph (fig 5 in your example) to also determine where the Vds and Vgs values needed to be by using a load line in the form:
id = (Vdd/Rd) - (Vds/Rd)
And by finding the intersecting of this load line with the appropriate Vds vs Id curve for the Vgs you want to find biasing characteristics. Is this method employed at all or is it mainly the one you have described?
We don't use Vds vs Id curve also. Why? Well the answer is quite simple.
The datasheet Vds vs Id graphs show typical value. Also in our circuit we will use different Vds and Id value range than it shows in the datasheet. So this Vds vs Id graph are not very useful in real life.
Hi there,
Selecting the appropriate Vgs and Vds values for a MOSFET amplifier can be a complex task, as it involves considering various factors such as device characteristics, circuit requirements, and performance objectives. While it is possible to estimate these values based on the datasheet, it is not always the most accurate or reliable method.
One approach to determining the appropriate Vgs and Vds values is to create a Vgs vs Vds curve, as your professor suggested. This will allow you to visually see the relationship between the two parameters and select a point that falls within the desired region of operation (in this case, the saturation region). However, this method may require some trial and error to find the optimal point, and it may not take into account other important considerations such as device temperature and variation.
Another approach is to use simulation software, such as Multisim, to model the circuit and test different Vgs and Vds values. This can provide a more accurate and efficient way of determining the appropriate biasing points for your amplifier. Additionally, some manufacturers may provide application notes or design guides that can help guide you in selecting the appropriate biasing points for their specific devices.
In general, it is important to carefully consider all relevant factors and use a combination of methods to select the best Vgs and Vds values for your specific amplifier circuit. It may also be helpful to consult with experienced engineers or seek additional resources for guidance. I wish you the best of luck in your design process.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
