RJLiberator
- 63
A semi-circle of radius R has a charge Q uniformly distributed over its length, which provides a line charge density λ. Determine E at the origin.
https://www.physicsforums.com/attachments/105239
I can tell by argument of symmetry that the Electric field will be pointing in +y direction.
If we take a sliver of the charge, call it dq, we will calculate the Electric field.
E = \left(\frac{1}{4πε_0}\right)\left(\frac{dq}{R^2}\right)sin(θ)
Also: \left(\frac{dq}{dθ}\right) = \left(\frac{Q}{π}\right)
so: dq = \left(\frac{Qdθ}{π}\right)
Now:
E = \left(\frac{1}{4πε_0}\right)\left(\frac{Qsin(θ)}{πR^2}\right)dθ
After calculating the integral from θ = 0 to θ = π I get the following answer:E = \left(\frac{1}{2πε_0}\right)\left(\frac{Q}{πR^2}\right)\hat{y}
Does this work appear to be correct? I want to make sure I get this easy material down before I go to the more difficult material in electromagnetism. If so, is it fair to say that the linear charge density typically symbolized as λ is equal to Q/π in this problem. Q is the charge in coulombs and pi is the length of the semicircle. So I could represent my answer as:
E = \left(\frac{1}{2πε_0}\right)\left(\frac{λ}{R^2}\right)\hat{y}
