Shape to the data that is showing
  • Thread starter Thread starter msticky
    Data Shape
msticky
I have a google spreadsheet with a display of numbers from a report that is ordered and the link below is the result of this data.
It seems to me that there is a shape to the data that is showing. This shape seams to be constant over time having the same shape with a leading edge on the left and a lagging edge on the right.
I believe that most of the activity is in the middle of the shape. How can I determine the load of each column that shows which columns are likely to result next?
https://docs.google.com/spreadsheet/ccc?key=0Ajurt2allTaddElHTGZyalZ0aDhpbDBSd1B6UWNoWmc&usp=sharing
Mathematics news on Phys.org
I'm sure it is possible to find some function which somehow gives those lines of data (each column is one measurement?), but without any model for the data this is just guesswork and won't tell you much.
Not sure what you mean without any Model
Well, let's look at an example:
3, 5, 7, how does the series continue?
9, 11, 13, 15, 17... would be an option. But if my series is "all odd prime numbers", this is wrong, and the series continues with 11, 13, 17 without the 9 and 15.
Data points are not sufficient to find (and verify) the correct pattern behind them. It really helps if you know where the numbers come from - what do you expect from those numbers, are there upper and lower bounds to them and so on.
Thanks anyway
Link closed
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
