What is the frequency of a tuning fork oscillating at 2770 rad/s?
The tuning fork oscillates at a frequency of approximately 441.4 Hz, calculated from its angular frequency of 2770 rad/s using the formula f = ω/(2π). The increase in loudness when held above a glass bottle full of milk may be attributed to resonance, where the fork's frequency matches the natural frequency of the bottle, amplifying the sound. This phenomenon is specific to this tuning fork among the set of ten due to its unique frequency characteristics. Understanding simple harmonic motion and resonance is key to solving such problems effectively.
Timiop2008
A tuning fork oscillates with simple harmonic motion described the equation:
x = 0.00150cos(2770t) (where t is seconds)
a) calculate the frequency in Hz of the tuning fork
b) Suggest why only this tuning fork (taken from a set of 10 forks) gets louder when held above a glass bottle full of milk.
I don't know how to go about this question. Any help greatly appreciated.
A look at http://en.wikipedia.org/wiki/Simple_harmonic_motion, especially at the first formula encountered, will give you the straightforward answer.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
