What Is the Shortcut for Solving Ohm's Law Problems Using P=IE?
  • Thread starter Thread starter yakabod
    Law Ohm's law
The discussion focuses on shortcuts for solving Ohm's Law problems, specifically using the formula P=IE. Participants explain that by using a pyramid diagram, one can easily rearrange the formulas for voltage (E), current (I), and resistance (R). A specific example involves calculating the current for a 140-watt electric blanket connected to a 120-volt outlet, which can be solved using the formula Current = Watts / Voltage. The key takeaway is that understanding the relationship between watts, volts, and amps simplifies the calculations. Mastering these basic formulas is essential for efficiently solving electrical problems.
yakabod
What is the shortcut on solving problems that deal with ohms law?
You'll have to be more specific.
E
I | R
Here is a pyramid so if you want to solve for eg; E = IR. Just cover up what you want to solve for and the remaining letters left are your formulas. Another eg; I = E/R. Is that what you mean, sir? Does that help?
Dx :wink:
ok well i have problems here that I am done with already. dealing with the calculating the current.
used these kind of formulas:
resistance = voltage/current
and
current = voltage/resistance
now i was asking if there was easier shortcuts on solving these.
now looking at the last problem i am stuck. instead of asking for ohms or amps it asked find the current of a watt.
Code:
calculate the current in a 140-w electric blanket connected to a 120-v outlet
now my question is how to solve that with a diffrent formula? what formula is this?
That's not short enough for you? [?]
You need to learn basic units, and you need to start reading your book. I am not going to tell you the formula, because that gives away the whole thing. I am going to ask you a couple of questions that will lead you to the answer.
1. What quantity is measured in Watts?
2. Is there a formula in your book that relates the quantity in #1 to current (answer: YES, there is).
Ohm's Law:
The pyramid is "V" on top, with "I" and "R" on the bottom. It can be expressed as three complimentary equations:
1) Voltage = Current * Resistance.
2) Current = Voltage / Resistance.
3) Resistance = Voltage / Current.
Any time you have two of the factors from one side of the equation, you will know the third factor (the other side). In your question "calculate the current in a 140-w electric blanket connected to a 120-v outlet"[/color], you have Watts and voltage.
Now you need to figure out what the "Watts" means. Watts is volts*amps. Again, you can draw a pyramid to help remember it all. Put Watts at the top, and across the bottom you have volts and amps (amps being current). Again, this allows three expressions:
1) Watts = Voltage * Current.
2) Current = Watts / Voltage.
3) Voltage = Watts / Current.
Now, Watts is voltage*amps. Since you know the Watts and voltage, you can divide Watts by voltage to get current. 140/120 = 1.15 Amps, roughly.
Now you have two factors necessary for working with Ohm's Law. You have the voltage (120) and the current (1.15).
The short version:
Watts = voltage*amps.
You've got voltage and watts: watts (140) = volts (120) * ?.
So, by re-arranging the factors you can get: ? = watts (140) / voltage (120).
Simply fill in the "?".
remember P=IE, my friend.
