Shortest possible period of revolution of two identical gravitating solid spheres
The discussion revolves around calculating the shortest possible period of revolution for two identical gravitating solid spheres in circular orbit. Participants analyze the gravitational force and centripetal acceleration, leading to the formulation of equations for the period of revolution. Key corrections are made regarding the distances used in the equations, particularly distinguishing between the distance between the centers of the spheres and the midpoint. The final consensus arrives at the equation T=(16π²r³/Gm)^(1/2), with emphasis on ensuring consistent definitions of variables. The importance of careful unit analysis and the relationship between mass, density, and volume in the context of the problem is also highlighted.
autodidude
From K&K's 'Intro to Mechanics'
Find the shortest possible period of revolution of two identical gravitating solid spheres which are in circular orbit in free space about a point midway between them.
So I figured the gravitational force exerted on each sphere by the other would be
F=\frac{2mg}{r^2}
according to Newton's law of gravitation (m being each sphere's mass). This force would be providing the centripetal acceleration that's keeping them going in a circle so the angular velocity can't exceed a certain value and this is related to the period of revolution.
F_c=\frac{2mG]{r^2}=m\frac{v^2}{r}
∴(\frac{2G}{r})^{1/2}=v
So plugging that into T=\frac{\omega}{2\pi} gives me T=(\frac{G}{2\pi^2r^3})^{1/2}
Is this correct? If not, am I at least on the right track?
Thanks in advance
Your final equation suggests that as r tends to infinity then T tends to zero. Does that sound reasonable?
Your method is essentially right but you have got errors in the details of your equations.
Applying Newton's law of gravity gives a force of F=-\frac{Gm^2}{r_d^2}
Which should be equated to centripetal force (as you rightly did)
F=-\frac{mv^2}{r_r^2}
Notice I have two different distances
rd= distance between centre of spheres
rr= distance between a spheres centre and the midpoint between the spheres
clearly rd=2rr
Your equation for T was wrong and it is more useful to use
v=\frac{2\pi r_r}{T}
thanks apelling, redoing it i got:
T=(\frac{4\pi^2r^3}{G})^{1/2}
but when I looked at the units, I seem to have a mass unit in there
You should get
T=(\frac{16\pi^2r^3}{Gm})^{1/2}
With r being the distance between the centre of a sphere and the midpoint about which the spheres rotate.
Now I suspect you need to replace the mass m with density x volume of a sphere. This introduces another distance: the radius of the sphere. For minimum time period the orbital radius r should be a minimum. What is the smallest it can be?
Oh, thanks...back to work then! Wow, you got to be really careful when doing these problems in this book!
alright I'm so close now...i realize the mistake i made before was adding the masses rather than squaring. my answer now is like yours except i have a 4 in place of your 16
let r= distance between centre of sphere and midpoint between spheres.
then distance between centres of spheres=2r
We then get
F=-\frac{Gm^2}{4r^2}=-\frac{mv^2}{r}
which simplifies to
\frac{Gm}{4r}=v^2
Subbing in
v^2=\frac{4\pi^2 r^2}{T^2}
leads to
Redoing it once again, I now have an 8. I've been taking r to be the distance between the two bodies and so have r/2 for the centripetal force side...but shouldn't the same answer pop out?
\frac{Gm^2}{r^2}=\frac{2mv^2}{r}
(\frac{Gm}{2r})^{1/2}=v
T=(\frac{8\pi^2r^3}{Gm})^{1/2}
Are you using
v^2=\frac{\pi^2 r^2}{T^2}
No, I'm using
But same answer if I use the squared version
You should be using r/2 in this equation to be consistent with your definition of r.
Hmmm...I've just redone it a few times now and I'm now getting a 2 (have tried another formula as well, T=2pi/w, which gives the same answer). I'll keep checking though...must've made another error somewhere.
The 2 is correct. I got 16 because I used r=1/2 separation of masses. When cubed in the final equation this leads to a factor of 8 difference. 2 x 8 =16
Ah yeah...thanks a lot for your help apelling!
