Calculating Normal Force on a Sliding Child - Homework Solution
  • Thread starter Thread starter linnus
To calculate the normal force exerted on a 22.0 kg child sliding down a 37.0° slide, the formula Fnormal = mg cos(x) is used. The initial calculation yielded -172N, which was incorrect due to a sign error. The correct magnitude of the normal force is 172N. The confusion arose from misreading the question, highlighting the importance of careful reading in problem-solving. Accurate calculations are essential for understanding forces in physics problems.
linnus
A 22.0 kg child slides down a slide that makes a 37.0° angle with the horizontal. What is the magnitude of the normal force that the slide exerts on the child?
Fnormal= mg cos (x)
Fnormal= 22.0kg(-9.80m/s^2) (cos 37)= 172N...but that's not right
I'm so confused..thanks for helping
frictionless?
that's the value i got.
ah, I see I didn't read the question carefully enough @_@ I put -172N for the answer instead of 172. Thanks!
