Solve Simple 2D Ballistics Equations: Max Height, Velocity & Distance
  • Thread starter Thread starter Torquescrew
    2d Ballistics
The discussion revolves around solving a projectile motion problem involving a rock thrown from a 30-meter tall building at a speed of 60 m/s and an angle of 33 degrees. The calculations provided include determining the maximum height reached, the velocity just before impact, and the horizontal distance traveled. The maximum height calculated is approximately 54.4 meters, with a final velocity of about 40.7 m/s before hitting the ground, and a total horizontal distance of 376.4 meters. Concerns are raised about the realism of the scenario, as the required throwing speed exceeds typical human capabilities. The calculations appear correct, but the unrealistic parameters lead to doubts about the problem's validity.
Torquescrew
Well, finals are coming around. I'm reviewing stuff I thought I learned at the beginning of the semester only to find out that I don't remember what I'm doing. It's pretty easy until I forget everything.
I think I have a handle on this, but I just want some verification to make sure I'm doing it right.
A man stands on the roof of a building that is 30.0 m tall and throws a rock with a velocity of magnitude 60.0 m/s at an angle of 33.0° above the horizontal. Calculate a) the maximum height above the roof reached by the rock; b) the magnitude of the velocity of the rock just before it strikes the ground; c) the horizontal distance from the base of the building to the point where the rock strikes the ground.
I'm a big fan of using these:
Vf=Vo+a(t)
(delta)x=Vo(t)+.5(a)(t^2)
(delta)x=[Vf^2 - Vo^2]/2a
and some basic trig
For (a), I chopped up my initial vector into x and y components.
Vox = 50.3202 m/s
Voy = 32.6783 m/s
Then, I figured I'd not only see how far up it would go, but how long it would take to get there.
For time, I used:
0=32.6783{m/s}-9.81{m/s^s}*t
I wound up with 3.3113 seconds
Next, I got the same result of 54.4278 meters (above the roof) whether I used this equation
(delta)x=Vo(t)+.5(a)(t^2) <--using the time I had previously solved for
or this one
(delta)x=[Vf^2 - Vo^2]/2a <--ignoring time altogether
Then, for (b) I added the 54.4 meters to my initial 30 and solved for a new time (this one for it's downward movement) with this one again:
84.4...=0+(.5*9.81*t^2)
Netted myself another 4.14881 seconds
Using this new time, I solved for my final y velocity with
Vf=Vo+a(t)
Vf=0+9.81*4.14881
I wound up with 40.6998 m/s
I verified by using this formula:
Vf^2=Vo^2 + 2a(delta x)
or rather
Vf^2=0+(2*9.81*84.4...)
Then, I used the handy formula for building one vector out of 2:
[(x^2)+(y^2)]^(1/2) <-- somebody is gonna' have to teach me how to type a "square root" symbol
[(50.3202^2 m/s) + (40.6998^2 m/s)]^(1/2)
I now have a vector magnitude of about 64.7 m/s
Lastly, for (c), I added my two times together
4.14881+3.3113
Very nearly 7.5 seconds in flight.
I multiplied my initial x vector by the flight time to see how far it flew before it landed.
50.3202 m/s * 7.47993 s
So it looks like this guy threw a rock 376.4 meters.
That's over three and a half football fields.
Either this guy has one heck of an arm (60 meters a second initial velocity? Madness!), or I royally jacked this up.
Am I crazy? More importantly, are my calculations correct?
Something just seems out of place and I can't put my finger on it.
Your answer is correct.
Yup, the man does have one heck of an arm.
I am a senior high school student and I hate it when there are problems that do not even try to be semi-realistic. It leads me to believe that my answer is incorrect somehow.
Heck the man in this problem broke the record pitching speed for a baseball.
