Finding the Magnitude of a Vertical Force in a Simple 3D Statics Problem
  • Thread starter Thread starter Ortix
    3d Statics
To determine the magnitude of the vertical force F in the 3D statics problem, the tension in cable AB is given as 700N. The approach involves breaking down the tension into its x, y, and z components, leading to three equations with three unknowns: F, AC, and AD. While the original poster feels overwhelmed by the calculations, it's emphasized that using unit vectors (i, j, k) simplifies the process, especially when angles are not provided. The key is to treat the total tension as 700N rather than its components. Overall, the solution requires careful component analysis and application of static equilibrium principles.
Ortix
If cable AB is subjected to a tension of 700N determine the magnitude of the vertical force F in N.
Pic:
[PLAIN]http://img225.imageshack.us/img225/9823/capturespm.png
Sum of forces in x y and z direction
I am retaking my statics course after i switched majors (long story) and i kind of forgot how to solve this the RIGHT way.
My approach would be first breaking up all the tensions in the x y and z components and summing all of those. I'll end up with 3 equations and 3 unknowns (F, AC and AD). I just feel like that's too much work...
On top of that my book makes use of i j and k but in those problems angles are given (which does make it easier to calculate the components)
Could someone give me a quick rundown on how to solve this?
Sounds like you're doing it right. You've got the forces broken down, solve for the unknowns. Make sure that you're assuming |AB| to be 700N not anyone component of it.
turns out working with unit vectors and i j and k is much easier! Thanks for the reply though!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
